Nokia E61 on 3 UK Can't unlock ???? Hi, I am trying to unlock Nokia E61 on 3 UK but I am getting a message Failed to read info -> Failed to read SP info When I try to read the info, can you please help. Cheers |
Use the yello adapter when working with the BB5 phones.. If you can't read the infos go before in the BB5/Flash tab and click on check flashing bus the mobile should be seen and afterward you can read the infos. |
Uste the tx2 adaptor (The yellow cable) Click on back-up PM Thick where says "skip sp info" Click on Unlock... Everything will be fine BR Alex |
Hope and am sure in major release all Problem regarding Reading SP area on BB5 phone mainly will be solved then no need to skip |
Hi, Thanks for your reply but the message I am getting after skipping and try to unlock: CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002100 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000341 CMT_PUBLIC_ID: 0B600008EE974F5777741C3C973353FC302A083B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_ROM_ID: F28A211FAC901AEE RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... BB5 Unlock Failed -> Failed to Boot / Prepare Phone Cheers |
U r Using yellow adapter ? and ur cable is good for local test mode ? first check flashing bUS when all went ok then proceed for unlocking Or if that not help try unticking use TX2 line option |
All initialized - Ready to work MCU Version V 05wk07v41 MCU Date 08-02-06 Product RM-84 Manufacturer (c) Nokia. IMEI 359380001801748 Mastercode 271355362 IMEI Spare 3A95830010087104 IMEI SV 3395830010087104F6000000 PSN CII778715 Product Code 0529914 Basic Product Code 0522156 PSD 0000001700000000 RETU 32 TAHVO 52 AHNE 22 HW 6012 RFIC 150a160e DSP rolf_05wk07v24 Failed to read info -> Failed to read SP info I can't understand why my box does it with every phone. I have tried 5 different phones with same error message. I have the yellow cable connected to unlock. It does read the card, it does to coonect to cyclone team server but it doesn't connect to phones. Cheers |
Don"t use TX-2 adapter. In your hands N70. (RM-84, IMEI 359380001801748). Just try unlock it without any adapter. |
BR Alex |
Hope that will be fixed in upcomming major Update..but no worries u can perform all operation without any problems TX2 adapter is Must and recommended for All operations regarding BB5 servicing |
Hi, I have unticked the tx2 adapter, I have ticked Skip SP read. I have connected my phone using JAF adapter to cyclone box direct, I still get the following message: BB5 Unlock Started... MCU Version V 05wk07v41 MCU Date 08-02-06 Product RM-84 Manufacturer (c) Nokia. IMEI 359380001801748 Mastercode 271355362 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 64D8F30085754B3DD535E5ABBADBCB044651AB73 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_ROM_ID: AB5E4ADB27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 19C0011685A4495136AFC59AB486E6B19B3193E0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_ROM_ID: F28A211FCEA7B19D RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22FA00000011, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Booting RAP... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 64D8F30085754B3DD535E5ABBADBCB044651AB73 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_ROM_ID: AB5E4ADB27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 19C0011685A4495136AFC59AB486E6B19B3193E0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_ROM_ID: F28A211FCEA7B19D RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... BB5 Unlock Failed -> Failed to Boot / Prepare Phone What next please !!!!!!!!!!!!!! |
when you get the error the mobile how is? (Local mode, test mode, switched on as under battery) BR Alex |
local mode 1st time no problem putting it in local or test mode |
Switch on like under the battery |
How can I put a phone on local / test mode please, maybe the issue is there ????? Cheers |
