Please help me Flash Nokia E63 - rm 437 Hi! Please help me! I downloade Flash file for Nokia e63- rm437 . However, when i try to flash, i did not know which file i need to select. it does not have file as .MCUsw, image or ppm file..... It only have .pcx or .prd file or something like that. Please explian me how to flash nokia e63 which flash file should i need to choose.....? If can, please post me 3 correct flask file to flash nokia E63 - rm 437. thank you Tommy |
Donwload all the files related to the product code you need using navfirm. Once you did you will be able to use the auto selection with the VPL vfiles.. easier. Anyway here a sample : MCU = prd.C00 , PMT = prd.V277_20 , CNT = _20.277U BR Alex |
Thank you! I did flash succesfully. however after flash, I try to unlock, it come with error when read Info and unlock: 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia , ADSP DevID 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia , ADSP RevID 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia , AEM 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256 Flip MCUSW 110.21.006j 110.21.006110.21.006_v29kRM437ENO874571920.a01n256 o256 Failed to read info -> Failed to read SP info BB5 Unlock Started... MCU Version V ICPR71_09w04.2 MCU Date 19-02-09 Product RM-437 Manufacturer (c) Nokia IMEI 356939031667867 Mastercode 4323355222 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 5050300014981890 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1230011091A88B525E69AEB387DA9B0603CA9D38 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1230011091A88B525E69AEB387DA9B0603CA9D38 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! BB5 Unlock Failed -> Simlock Array not found in PM 308, this is critical And this is selftest: Selftests to proceed: 33 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Failed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Passed ST_BT_WLAN_COEXISTENCE_TEST Passed ST_RADIO_TEST Selftests done, Tests total: 33, Tests passed: 31, Tests not passed: 2 Please advice me, now phone Can turn on BUT IT ALSWAY SAY INVALID SIMCARD. thank you tommy |
Hi! I did try to write original RPL back, It is still same problem: Working on PM... Configuration Key - Found SHA1-RSA - Found SHA1-HMAC - Found Signing Configuration Key... Building RPL... RM-437_356939031668717_14112009_121102 PM.SLBackup.RPL Saved OK! Failed to Write RPL File -> RPL File invalid, not begins with `REBUILD DATA` Magic, Maybe it is PLAIN ONE ? Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0970011091A88B52CF9FD35E58CD9E954B50539C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0970011091A88B52CF9FD35E58CD9E954B50539C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... Write RPL Finished! then MCU Version V ICPR71_09w04.2 MCU Date 19-02-09 Product RM-437 Manufacturer (c) Nokia IMEI 356939031668717 Mastercode 3422351327 IMEI Spare 3A65390913667801 IMEI SV 3365390913667801F4000000 PPM 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 PSN MWH181633 Product Code 0583813 Basic Product Code 0561985 PSD 0000000000000000 LPSN 0 WLAN MAC 1886AC2571A7 APE SW 110.21.006 APE Variant 110.21.006110.21.006_v27 APE Test RM437ENO874571920.a01 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0802i110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 PCI i110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 UEM 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 UPP 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 RFIC 17141715 DSP Sofie_ICPR71_08w41i110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia , LCD 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia , BT 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia , ADSP Sw 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 ADSP DevID 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 ADSP RevID 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 AEM 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256 Flip MCUSW 110.21.006j 110.21.006110.21.006_v27kRM437ENO874571920.a01n256 o256¥0)110.21.006, 02-03-2009, RM-437, (c)Nokia , Failed to read info -> Failed to read SP info Please help me, I got 2 nokia 363 like that thank you tommy |
Hi! Big problem for me now, After try one more flash for 2 Nokia e63. Phone Not turn on or go to local mode at all. What should i do now, Phone is dead. Thank you tommy |
Flash it with the ENO firmware for the E63 and flash it again with the firmware was in the mobile before it got dead. About the simlock problems for sure the mobie has the PM120 field 0 changed by unlock so you should rebuild the PM 120/0 as original to have a RPL from PM working. BR Alex |
Hi! I forgot to Read all certificate, I only do Create RPL and back up Pm. Now phone got imei: 12345........ And i do not have certificate to write it back. Please let me know is there anyway to rebuild imei to original? Thank you Tommy |
I got 2 Nokia e63 dead after download from USA server and flash them. IT NOT really good. Phone woking before and now dead after flash, I do not how to fix them. Phone can not read info and go to test mode. Tommy |
if rpl and pm was read as full area of both then u can restore rpl and pm to revive the set after flashing with eno software. if again simlock not read then make rpl from ur fully read pm and write to fone as plain rpl and post result |
Thank brother... What is ENO sofware meant? thnk you |
Untick Erase Security and write RPL file again. |
