03-20-2009, 18:02 | #2 (permalink) |
Registered User Join Date: Sep 2007 Location: RO, Bucuresti
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | The box come only with one adaptor. End the cable is Full com patibile with JAF/UFS/UB BOX etc . Today a buy this box end a will post the result. I think it is time for another team to hold the monopoly for nokia I hope I did well I bought this box and the Update will be quite regular. Boxing is not exactly expensive at 99 euros. |
The Following User Says Thank You to ServiceTEL For This Useful Post: |
03-20-2009, 18:05 | #3 (permalink) |
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | [IMG]http://www.***************/pictures/gallery/02b.png?rand=209926374[/IMG] [IMG]http://www.***************/pictures/gallery/06b.png?rand=148942293[/IMG] [IMG]http://www.***************/pictures/gallery/03b.png?rand=48661095[/IMG] I understand that for mondey to find out more information, however one I bought him. |
03-21-2009, 16:56 | #5 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | Quote:
service mark on dc jack (round one) and rj45 adapter cable. br. | |
03-21-2009, 21:46 | #8 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | is compatible ufs USB BUS powered only, current in idle is 55mA World's first flexible configurations via software. It can be used TX2 pin on any RJ48 output i/o pin. First in the world built-in 10 pin diagnostic service for measuring phone damages via: voltage, current, frequency, STI BUS High speed flasher, real BUS speed up to 10-11Mbit, using 2 data lines UFS/JAF compatible pinout Switchable VPP - externally or internally generated signal, high speed flashing/erasing Advanced self-testing system Supports both FLASHBUS and USB connections for Nokia phones Built-in secure smart-card Cyclone Box uses it's own Smart Card and FTDI drivers so there are no conflicts with other devices Free 100 ASK-RPL credits are included into Cyclone Box pack to perform RPL calculation for Nokia DCT4 and DCT4Plus. The user does not wait to calculate ASK-RPL online. |
03-23-2009, 14:33 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Keep cool, its not real pictures, just 3d projection Real casing is corrected (180degree) |
The Following User Says Thank You to karwos For This Useful Post: |
03-23-2009, 14:33 | #10 (permalink) |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Keep cool, its not real pictures, just 3d projection Real casing is corrected (180degree) About cables and pinouts you can check sticked thread, I described it enough, i think. |
03-24-2009, 19:44 | #15 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | The Box could be better, if pins 2 and 10 are swapped SERVICE socket (10 pin layout) 1 - BOX GENIO1 2 - VBAT (5v) 3 - BOX GENIO2 4 - BSI 5 - BOX RX_1 6 - BOX TX_1 7 - MBUS 8 - GND 9 - VPP 10 - BOX GENIO3 Mt-Box Best regards |
The Following User Says Thank You to Aishur For This Useful Post: |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
Planning on getting Cyclonebox, should I get with cables? | zapped | Cyclonebox | 6 | 10-31-2009 19:51 |
Cable set for cyclonebox....... | yentrang120705 | Cyclonebox | 10 | 05-17-2009 08:21 |
cable cyclonebox ,??? | sagemx1 | Cyclonebox | 10 | 04-09-2009 11:33 |
