05-12-2011, 18:41 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Pandora
Member: 385139 Status: Offline Thanks Meter: 12 | nokia 7230 log reading failed,help.. <code>Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.61, (May 10 2011 21:52:47, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 wk9 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00021C4 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D4000*** Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,05v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,02v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,92v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 06.90 MCU Date 26-02-10 Product RM-604 (Nokia 7230) Manufacturer (c) Nokia IMEI 35375604898**** Mastercode 1016564562 IMEI Spare 3A35570684894504 IMEI SV 3335570684894524F4000000 PPM V 06.90, 26-02-10, RM-598, (c) Nokia , SP CNT Content: vodafone ES, V 06.90, 26-02-10, RM-604, (c) Nokia , , PSN HFF251098 Product Code 059B4N0 Module Code 0204267 Basic Product Code 0585700 PSD 0000000000000000 LPSN 0 RETU 40 TAHVO 00 AHNE 41 HW 1000 RFIC |Vapaus_5.1 | Mikki_1.1 DSP ICPR91_10w04_1 LCD SEIKO BT 1673-46034 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading SL3 LOG File... MCU Version V 06.90 MCU Date 26-02-10 Product RM-604 (Nokia 7230) Manufacturer (c) Nokia IMEI 35375604898***** Mastercode 1016564562 WARNING: "2DA0000AE832004977B52ADA453548D0F40FA830.C00021C4 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Prepare phone failed with message -> Failed to Boot CMT Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) Failed to Read SL3 LOG File -> Failed to obtain Phone Unique Data Reading SL3 LOG File... MCU Version V 06.90 MCU Date 26-02-10 Product RM-604 (Nokia 7230) Manufacturer (c) Nokia IMEI 35375604898**** Mastercode 1016564562 WARNING: "2DA0000AE832004977B52ADA453548D0F40FA830.C00021C4 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Prepare phone failed with message -> Failed to Boot CMT Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) Failed to Read SL3 LOG File -> Failed to obtain Phone Unique Data</code> help please... |
05-30-2011, 13:25 | #2 (permalink) |
Junior Member Join Date: Dec 2005
Member: 207195 Status: Offline Thanks Meter: 0 | failed nokia 3710a....why? Reading SL3 LOG File... MCU Version V 04.35 MCU Date 20-04-10 Product RM-509 (Nokia 3710 fold) Manufacturer (c) Nokia IMEI 35432004xxxxxxx Mastercode 7076606245 Warning: Failed to read SP Info, Assuming defaults Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS 15 Digits NCK Found WARNING: "2E9002017242004989A5B557046584F9C992421E.C0001C18 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Prepare phone failed with message -> Failed to Boot CMT Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) Failed to Read SL3 LOG File -> Failed to obtain Phone Unique Data |
05-30-2011, 13:27 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
06-22-2011, 18:29 | #10 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Earth Age: 54
Member: 17189 Status: Offline Thanks Meter: 66 | it worked at last this diagram worked but very funny it worked on only one phone not the second one strange now I noticed when changing in the options of the direct unlock the boot cmt would change I already ordered a new cable |
06-23-2011, 13:39 | #12 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | RAP4 really need good, preferrably shielded cables. Plus dual mbus, plus Digital ground shorted with Battery ground (most common china cables have floating Digital ground!). |
The Following User Says Thank You to karwos For This Useful Post: |
06-23-2011, 14:45 | #13 (permalink) |
Member: 17189 Status: Offline Thanks Meter: 66 | wow interesting now we have a new shorted config.. thanx karwos for reply I need to know which is digital gnd ?? I did the first dual mbus shortcut and it worked as I said with one of the fones very easy the second is giving me troubles I think the digital gnd is the problem thanx in advance |
06-23-2011, 15:04 | #15 (permalink) |
Member: 17189 Status: Offline Thanks Meter: 66 | well that is good I checked the cable again it is a BX serie from IP-mart both gnd's are connected but I connected the cable now without the back cover and tested it during the LBF read process while it was waiting for CMT boot I kind of lost grip and re-attached the connector to phone very fast suddenlly it continued the read process and now I have the log file I tried again with full cable not working but the trick of taking cable off and on goes well so now I have log file on both fones the rest is not important btw do you know some trusted guys that count codes at good price thanx |
