Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-26-2009, 13:42   #1 (permalink)
DaWizard's Avatar
Member: 61557
Thanks Meter: 130
Exclamation Is NM706i Unlock Supported ? ? ?
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 03500119899401584EF2EC2E033A7ABD87DA8320
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C
CMT_ROM_ID: 4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC003000400221, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 3DCFBD5EF6437C46BEB6D5B735A0C79F83656E0D
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
BB5 Unlock Failed -> Failed to get Lock Key (6);
What seems to be this Error
Old 06-26-2009, 13:46   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
post read INFO here................
Old 06-26-2009, 20:07   #3 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Unlock it without using the code calculation.. made one one week ago.. you can find the logs in the successfull sories
http://forum.gsmhosting.com/vbb/show...&postcount=156
Alex
Old 06-27-2009, 07:22   #4 (permalink)
DaWizard's Avatar
Member: 61557
Thanks Meter: 130
Alex
Man
How to unlock without code calculation? Pls need procedure
Old 06-27-2009, 07:37   #5 (permalink)
moulnisky's Avatar
Member: 947561
just answer no when it says : calculate codes?
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 06-27-2009, 07:55   #6 (permalink)
DaWizard's Avatar
Member: 61557
Thanks Meter: 130
Alex
Thank you so much man.....
Old 06-27-2009, 07:57   #7 (permalink)
moulnisky's Avatar
Member: 947561
You are always welcome mate :-)
Alex
Old 06-27-2009, 10:14   #8 (permalink)
joe-25's Avatar
Member: 767423
Sonork: Magnet now
Thanks Meter: 27
use universal box solve your problem...in a seconds......
Old 06-27-2009, 13:23   #9 (permalink)
moulnisky's Avatar
Member: 947561
Already unlocked by Cyclone... without any activation and with a box which cost 66% less then universal box and all updates are free..
better ;-)
Alex
Old 06-29-2009, 05:23   #10 (permalink)
vino_89's Avatar
Member: 935830
Thanks Meter: 157
NM706i IS now Supported by cyclone......
very perfect
good update cyclone team.............
Old 09-08-2009, 11:57   #11 (permalink)
Member: 505218
Thanks Meter: 120
Nokia NM706i Docomo unlock OK
Thanks Cyclonebox.
Old 09-08-2009, 12:23   #12 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
Now, anybody have firmware for NM706i??
Please I need it despretely cause misunderstood by flashing with 6120 firmware :-(
Old 09-17-2009, 06:49   #13 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
Sir, try to flash using 6122c/ 6124c fw
hope this help
br,
Old 09-17-2009, 08:29   #14 (permalink)
gsmTECHNICIAN's Avatar
Member: 922938
Thanks Meter: 59
good report
tnxx for feedback
RyanMuslim
Is E63 unlock supported by mt-box,Thanks! joer MT-BOX 4 07-25-2009 07:14
Is Ultimate Unlocker Support K510i DB2012 CID 50 ?!? gone_bdg Cruiser Suite 6 06-28-2009 22:48
is 6600s unlock supported? heramiah BB5 Box by D.K. 3 06-19-2009 22:38
There is no unlocking support for Nokia 2660 in new hwk 2.0.6.0 milkyctg HWK 0 11-12-2007 00:57
Is P910 unlock supported yet ???? Gsmkings NSPRO 0 08-07-2006 19:56
Page generated in 0.23294 seconds with 9 queries
