Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Pegasus
Old 06-12-2011, 00:16   #1 (permalink)
.::koolfriend4u::.'s Avatar
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
Arrow B3210 carby dead after flashing-recovered via opti flash
6/12/2011 2:49:31 AM SAMSUNG B3210 :
                      [ --- CONNECTING TO THE PHONE --- ]
HARDWARE PLATFORM           : TRIDENT I
SETUP LOADER VERSION        : 02.00.07
MAIN LOADER VERSION         : 05.22.00
FLASH #1 TYPE               : INTEL 1024XX
FLASH #1 SIZE               : 67108864 BYTES
FLASH #2 TYPE               : INTEL 1024XX
FLASH #2 SIZE               : 67108864 BYTES
CHANGING BAUDRATE TO 460800 : COMPLETED
SETTING UP MAIN LOADER      : COMPLETED
                        [ --- WRITING MAIN FLASH --- ]
THERE ARE 38526290 BYTES IN 09 REGIONS TO WRITE
WRITING MAIN FLASH          : COMPLETED (00:23:26)
                       [ --- CREATING FILE SYSTEM --- ]
THERE ARE 13905872 BYTES IN 92 FILES TO WRITE
FORMATTING FILE SYSTEM      : FAILED
now phone in hang state..earlier it was good working,but in lock !!
Samsung B3210 CorbyTXT -Tutorial
In this Tutorial you can learn the right and easy steps to Update the firmware of Samsung B3210 CorbyTXT So read carefully and follow it one by one.
Tools : Samsung B3210 CorbyTXT Downloader - Original USB cable.
Flashing Steps :
  1. Run Samsung B3210 CorbyTXT Downloader.
  2. Select Customer T: Rodeo (Intel Sibley 1024/256, USB).
  3. In Flash Option section check: Code Binary and CSC Binary(Default).
  4. Also check this Option: Erase all Unused Regions.
  5. Connect the phone in Download mode: Press * and connect USB cable to phone.
  6. Now select the Com Port that the phone takes.
  7. Select the S3 Flash file and CSC file too, each in his field.
  8. Click on Flash button and type YES in the message box then click OK to Start the process.
  9. Do not touch or remove the cable till the Program telsl you: All is Well.
  10. Turn On the phone and do full reset by this code: *2767*3855#.
The Following 2 Users Say Thank You to .::koolfriend4u::. For This Useful Post:
Old 06-12-2011, 04:18   #2 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 767
With pegasus you flash via usb or RJ.?
The Following User Says Thank You to nongmobile For This Useful Post:
Old 06-12-2011, 04:23   #3 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 767
Old 06-12-2011, 04:33   #4 (permalink)
Registered User
Member: 231606
Sonork: cellphone_training@yahoo.
Thanks Meter: 64
advice dont always trust instantly for new box they have no tested logs yet if i were you trust only those who already tested like ust pro ,ns pro, z3x..id experience also with there octupos and medusa theyre all new one will kill the unit after flash and the other will make it alive but its not perfect ,,,,,, till now my unit is still here hang up in logo before its ok i only unlock it in octopus after unlock its hang in logo as they told me to buy medusa to make it alive but after i bought till now my phone is in cyon logo only and they advice its hardware fault huhuhuhuhu
very dis appointing
Old 06-12-2011, 07:03   #5 (permalink)
Sanchez's Avatar
Member: 1896
Thanks Meter: 101
Flashing Steps :
Hi, its happens sometimes that CSC flashing fails from first time. The solution is just to flash CSC only again using pegasus.
The Following 2 Users Say Thank You to Sanchez For This Useful Post:
Old 06-12-2011, 15:23   #6 (permalink)
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
@Sanchez
as u mentioned here..i tired every other option...
tried vis usb..
tried via rj45(auto ignition cable)
tried to flash CSC file n seperate too..but it fails in all way
@fixed
hi bro..the fact is i tried tht phone in all other sam tools(ufs/z3x)..both via usb/r.j45,then tried by flashing one file at a time..in all cases it fails.
i made this thread,just not to blame pegasus works or to critises...
im making this,just to increase the power of pegasus (by cut through some minor bugs)
we all know..the new boxes will never come up with full bugs free..it took time to fix those bugs.
I AM WAITING FOR PEGASUS TEAM TO FIX THOSE BUGS AT THE EARLIEST
NOTE
PEGSUS TEAM SHOULD ADD FLASHING WITH ORIGINAL FILES(must needed) IN ADDITION TO PEGASUS FILE(PGS)...or atleast to make option to convert original files to pgs files
THANKS IN ADVANCE
Old 06-12-2011, 19:57   #7 (permalink)
Sanchez's Avatar
Member: 1896
Thanks Meter: 101
@Sanchez
tried vis usb..
@fixed
NOTE
THANKS IN ADVANCE
Thanks for the info. Lets hope the bug will be fixed soon.
Old 07-02-2014, 04:35   #8 (permalink)
Member: 2168898
Thanks Meter: 5
pls upload the download link the download file
Old 05-05-2016, 14:03   #9 (permalink)
Crazy Poster
Member: 2205481
Sonork: 100.1667971
Thanks Meter: 28
Recover Done
Flashing Steps :
it's an awosome idea to recover dead phone...and finally i recover that.good
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
SMS via system connector pasisoft Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-21-1999 11:05
Page generated in 0.25874 seconds with 9 queries
