09-27-2009, 05:34 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 186479 Status: Offline Thanks Meter: 1 | 1110i Contact Service Phone Type: RM-305 SW version: V 5.51 16-06-08 RM-305 (c) NMP 17 TX_IDP_LOOP Y !failed ! Is it hardware or software problem? I tried to flash the phone with mxkey but the flash ic can`t be detected, but using jaf it`s ok. here is the log: Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! The phone showed "contact service" i have tried with other cables and still the same. I tried with 1650 the result is the same. what could be wrong with mxkey??? it`s all fine with jaf. here is the log with 1650 i used 2 normal 1650 phone) Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! |
09-27-2009, 05:57 | #2 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
1110i type is rh-93 and 1650 type is rm-305 flash ur set with rh-93 after flashing perform unlock (initsim ) problem will be solved | |
The Following User Says Thank You to cel_phon For This Useful Post: |
09-27-2009, 07:44 | #4 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | not always SW helps for this case Full erase Full flash Upload PM Unlock Factory Settings Thats all u can Do |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
1110i Contact Service............................. | lahoot | Nokia Hardware & Hardware Repair | 23 | 03-09-2009 13:25 |
1110i contact service | saeed-gsm | Universalbox | 3 | 12-12-2006 13:52 |
PLZ Help!!! Nokia 1110i contact service | muhammadjon_25 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-10-2006 09:13 |
1110i Contact Service | partmobile | UFS2 + UFS3-Tornadoflasher | 2 | 10-28-2006 19:19 |
1110i contact service | dolar | Nokia Digital Core Technology 4 ( DCT-4 ) | 12 | 10-11-2006 21:57 |
