10-30-2012, 08:25 | #1 (permalink) |
Banned Join Date: Mar 2011
Member: 1543138 Status: Offline Thanks Meter: 21 | 1110i flash imei empty......... here is log MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: Using device: HTI, FW ver: 00.50, SN: Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 894A B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00805487:2984DA60 ASIC type: 2 UEM Imei: 35325301773567 Flash Imei: Empty MasterCode: Invalid imei checksum ! |
10-30-2012, 08:49 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | It's Hardware, Quote:
Flash it again will solve it. Post reply. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
10-30-2012, 16:25 | #3 (permalink) | |
Member: 1543138 Status: Offline Thanks Meter: 21 | Quote:
sir can u explain any way to write rpl without local moad ? i think it is v7.2 provlem .............flash with this verworking fine 2 hour then set dead with flash imei empty............. | |
10-30-2012, 16:53 | #4 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
I think Phone having some Physical Damage, So Re-flow Flash+CPU, Reball Flash IC if possible, Again Flashing Process due to Phone Erased & got Error while writing Program. If not solve, Needs Flashing Logs after Reflowing or Reballing. BR, ZUBER | |
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post: |
