03-01-2010, 13:15 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: karoondi khairpur pakistan
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | 1112 cotect service how to solve plz help Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008A3DE2:2984DA60 ASIC type: 2 UEM Imei: 35551301111603 Flash Imei: 35551301111603 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\3555130111160 3_BA CK.rpl" Processing file: rh93_06.410 as MCU [DCT4,DCT4 ALGORITHM] size: 1.89 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008A3DE2:2984DA60 Area [01000000-0100FFFF] erased in 0.500 s Area [01010000-013BFFFF] erased in 26.125 s Area [013C0000-013EFFFF] erased in 1.484 s Area [017C0000-017EFFFF] erased in 0.313 s Area [01FC0000-01FEFFFF] erased in 0.328 s Flash programming ... Programming completed in 20.484 s File Processed in 1 min 8.141 s Processing file: rh930_nai6.41ic as CNT [DCT4,DCT4 ALGORITHM] size: 155.00 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008A3DE2:2984DA60 Area [01380000-013BFFFF] erased in 1.906 s Flash programming ... Programming completed in 1.875 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.203 s File Processed in 28.765 s Processing file: rh93_06.41ic as PPM [DCT4,DCT4 ALGORITHM] size: 1.36 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008A3DE2:2984DA60 Area [011E0000-011EFFFF] erased in 0.469 s Area [011F0000-0137FFFF] erased in 11.203 s Flash programming ... Programming completed in 14.766 s File Processed in 43.500 s Flashing completed in 3 min 3.797 s After Flash Processing ... Reseting Factory Values OK. Updating SIMLOCK ...Error 1 PhoneType:RH-93 SwVersion: V 6.41 06-04-07 RH-93 (c) NMP MCU file: rh93_06.410 Trying to find patch position ...OK, case id: 1 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008A3DE2:2984DA60 Area [01140000-0115FFFF] erased in 0.922 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x16 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008A3DE2:2984DA60 Area [01140000-0115FFFF] erased in 0.922 s Programming ... Programming completed. Phone Type: RH-93 SW Version: V 6.41 06-04-07 RH-93 (c) NMP Imei plain: 35551301111603-8 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IC Language Pack: English,Arabic,French,Swahili Imei net: 35551301111603 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED Total time to process is 4 min 33.985 s |
03-01-2010, 13:18 | #2 (permalink) |
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | i use letest virgions also but problem is same and set before flashing is ok after flashing i got this problem plz help i use mx key |
kp 170 ime 00000000000000000 how to solve plz help | asif_ae | Infinity-Box | 10 | 01-25-2012 11:29 |
n73 imei is : 12345610654321? how to solve plz help | neeraj1st | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 06-01-2011 10:08 |
1110i contact service how to solve this ????? | texas-gsm | Multi-Box | 5 | 07-22-2008 17:53 |
A100 No Service.. How To Solve? | bestncheap | Infinity-Box | 2 | 07-13-2006 12:40 |
C225 . Phone Locked Return For Servicing. How to Solve This Prob :) | Aamir_Zia | Trident/AGERE Platform | 13 | 08-06-2005 17:20 |
