1200 Imei ???????????4 plz help mx teem i have a set nokia 1200 with imei ??????????4 when i press online logger>dct4plus imei>do selected job its show ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C53FEB:DA3BDA66 ASIC type: 11 UEM Imei: 35352602150767 Connecting to server ...Socket error (10060): Connection timed out Or Connecting to server ...OK, Login ... then not responding affter that |
try manual u get sucsess............. |
Manual i tried manual but show this error ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C53FEB:DA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed Operation done with error. |
i have also get same problems but solved with above. thanks |
Reading imei... ??????????????? Opening RPL file... Inspecting... IMEI: 35352602150767 Booting phone... MCU ID: 0x2292 Sending algo... Algo is ready... Writting UEM... Error writting uem... |
take care |
use ufs hwk free rpl genrator |
when write new UEM have Quote:
then retry your operation br, |
