04-08-2010, 07:41 | #1 (permalink) |
Banned Join Date: Apr 2008
Member: 744438 Status: Offline Sonork: 100.1640287 Thanks Meter: 279 | 1200 Imei ???????????4 plz help mx teem when i press online logger>dct4plus imei>do selected job its show ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C53FEBA3BDA66 ASIC type: 11 UEM Imei: 35352602150767 Connecting to server ...Socket error (10060): Connection timed out Or Connecting to server ...OK, Login ... then not responding affter that |
04-08-2010, 08:11 | #3 (permalink) |
Member: 744438 Status: Offline Sonork: 100.1640287 Thanks Meter: 279 | Manual i tried manual but show this error ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C53FEBA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed Operation done with error. |
04-08-2010, 09:06 | #4 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: Adilabad
Member: 890104 Status: Offline Sonork: 100.1597567 Thanks Meter: 138 | Quote:
i have also get same problems but solved with above. thanks | |
04-08-2010, 10:01 | #5 (permalink) | |
Member: 744438 Status: Offline Sonork: 100.1640287 Thanks Meter: 279 | Quote:
Reading imei... ??????????????? Opening RPL file... Inspecting... IMEI: 35352602150767 Booting phone... MCU ID: 0x2292 Sending algo... Algo is ready... Writting UEM... Error writting uem... | |
04-08-2010, 10:48 | #6 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | Quote:
take care | |
04-08-2010, 11:18 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | when write new UEM have Quote:
then retry your operation br, | |
NOKIA 3110c imei 12345610654321? plz help | abi.m | Cyclonebox | 8 | 04-08-2010 05:34 |
plz help mx-key team(1209 UEM imei empty) | debapra_gsm | Nokia Hardware & Hardware Repair | 0 | 03-09-2010 11:13 |
(7210c phone will reboot itself after 3 min) plz help mx-key teem................. | shahinur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 02-04-2010 13:09 |
1200 imei????????????????4 help me | csm world | Nokia Hardware & Hardware Repair | 3 | 12-16-2008 18:36 |
1110i imei ????????????????4 plz help | shivamobiles | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 07-25-2008 16:54 |
