03-16-2010, 09:56 | #1 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | 1200 still in contact service Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! PhoneType:RH-99 SwVersion: V 6.00 30-09-09 RH-99 (c) NMP MCU file: rh99_06.000 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001243F7:2984DA60 Area [01000000-0101FFFF] erased in 0.859 s Area [01140000-0115FFFF] erased in 0.891 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 24.484 s Reading Simlock info ... Imei net: 35290302585566 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to xim360 For This Useful Post: |
2630 still in contact service | gsmsoftware77 | Universalbox | 1 | 03-20-2010 16:02 |
5220 contact service-repaired sd-write pm-still in contact service | zonetrichur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-07-2010 13:21 |
1200 in contact service | foo_men | Nokia Digital Core Technology 4 ( DCT-4 ) | 19 | 12-11-2008 22:34 |
5200 Still in contact service | marcvaz | MT-BOX | 2 | 07-08-2008 21:08 |
Flashed 3200 with powerflasher but still in contact service | macdan | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 09-03-2005 07:55 |
