11-11-2009, 17:19 | #1 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | 1202 flashing error Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0069BF14A3BDA66 ASIC type: 11 UEM Imei: 35694203474741 Processing file: rh112_003.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 Boot error: 03 00 00 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Flashing terminated with error(s) in 1 min 18.826 s RX Buffer: 33654902434747F142B372 i try 2 time but same error |
11-11-2009, 19:12 | #2 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | I Flashed with out Problem LOGS: ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755A3BDA66 ASIC type: 11 UEM Imei: 35********* Processing file: rh112_003.000 ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755:2984DA60 Programming MCU ... rh112_003.000: [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 Area [01000000-0100FFFF] erased in 1.125 s Area [01010000-013AFFFF] erased in 1 min 4.593 s Area [013B0000-013EFFFF] erased in 4.454 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.032 s Flash programming ... Programming completed in 14.797 s File Processed in 1 min 31.734 s Processing file: rh1120_nai03.00ia ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755:2984DA60 Programming Content Pack ... rh1120_nai03.00ia: [DCT4,DCT4 ALGORITHM] size: 166.05 KB Supported Ids: 2293 Area [01380000-013AFFFF] erased in 3.312 s Flash programming ... Programming completed in 1.078 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.093 s File Processed in 16.297 s Processing file: rh112_003.00ia ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755:2984DA60 Programming PPM ... rh112_003.00ia: [DCT4,DCT4 ALGORITHM] size: 1.08 MB Supported Ids: 2293 Area [01240000-0124FFFF] erased in 1.109 s Area [01250000-0137FFFF] erased in 21.141 s Flash programming ... Programming completed in 6.969 s File Processed in 34.875 s Flashing completed in 2 min 42.141 s BR |
11-11-2009, 19:19 | #3 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: India Age: 35
Member: 923397 Status: Offline Sonork: 100.1584169 Thanks Meter: 451 | Quote:
brother good shaire information its usefull for all members | |
The Following User Says Thank You to .::Raj::. For This Useful Post: |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
nokia 1202 Erasing error | samalik | HWK | 1 | 10-24-2009 18:29 |
1202 flashing | pearl87881 | Nokia Hardware & Hardware Repair | 1 | 12-27-2008 09:26 |
