Old 12-07-2009, 03:34   #1 (permalink)
ferdie1969's Avatar
Member: 883572
Thanks Meter: 63
1202 invalid uem why? phone is good
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11472, Date: 27-11-2009
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 0051C0EDA3BDA66
ASIC type: 11
UEM Imei: 35321103616849
Flash Imei: 35321103616849
MasterCode: 6056067101
RPL saved to "D:\mobileEx\3.3\data\backup\35321103616849_BACK.r pl"
Phone Type: RH-112
SW Version: V 03.00 14-11-08 RH-112 (c) NMP
Imei plain: 35321103616849-6
Product Code: 0562309
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MD
Language Pack:
- not available.
Imei net: 35321103616849
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Invalid UEM Data, No RPL backup will be made for this phone.
why is ti showing invalid uem? phone is working good
just wanted to try if mxkey could read it n creata a backup. cant create rpl backup
The Following User Says Thank You to ferdie1969 For This Useful Post:
Old 12-07-2009, 04:29   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
This is not important error
bcoz we cannot create rpl backup of "ASIC type: 11"
so don't worry and keep working.....
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post:
Old 12-07-2009, 04:37   #3 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
try to put the set in testmode/local mode manually and rpl can be backedup
it may be some minor bug nothing to worry
regards,
NEIL
The Following User Says Thank You to neilthirumuttam For This Useful Post:
Old 07-24-2010, 09:09   #4 (permalink)
Member: 596251
Thanks Meter: 33
1200
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00C523A1A3BDA66
ASIC type: 11
UEM Imei: 3567900239350
Phone Type: RH-99
SW Version: V 6.00 30-09-09 RH-99 (c) NMP
Imei plain: 3567900239350
Product Code: 0546860
ASIC ID: 0x2292, type: 11
Ppm Id: AA
Language Pack:
English,Dannish,Norwegian,Swedish
Imei net: 3567900239350
Counter: 0/3, 0/10
PROFILE_BITS: 800000000001000B
Old 07-31-2010, 06:33   #5 (permalink)
Member: 750024
Sonork: 100.1612548
Thanks Meter: 78
Arrow
yes dear its same problem but after a few minutes set start blanking. any idea
Old 08-01-2010, 14:16   #6 (permalink)
Temporary banned !!
Member: 482214
Sonork: 100.1617896
Thanks Meter: 316
NOKIA 1202 AFTER 30SEC OFF ANY SOLUTION?
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
UEM ID: 00B69D27A3BDA66
ASIC type: 11
UEM Imei: 35606803686189
Phone Type: RH-112
SW Version: V 03.10 21-01-09 RH-112 (c) NMP
Imei plain: 35606803686189-3
Product Code: 0562271
Ppm Id: IA
Language Pack:
- not available.
Imei net: 35606803686189
Counter: 0/3, 0/10
PROFILE_BITS: 000000000003000B
E66 invalid sim but phone is alredy unlock MUTUAL Cyclonebox 16 12-01-2009 08:37
Which Phone is Good myvicky Off Topic Zone 2 12-29-2007 10:09
Which Phone is Good myvicky Motorola P2k 2 12-21-2007 19:27
Which phone is good???please vote atin_garg2005 HTC & PDA WM( With Touchscreen) 5 10-31-2006 08:25
x400 invalid SIM but phone is unlocked?? ghosthacker Panasonic 7 09-08-2005 17:31
Page generated in 0.18876 seconds with 9 queries
