07-31-2010, 03:45 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 669987 Status: Offline Thanks Meter: 34 | 1661 contact service plz help ## (ANSWERED) Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00F4460EA3BDA66 ASIC type: 11 UEM Imei: Phone Type: RH-122 SW Version: V 03.70 14-04-09 RH-122 (c) Nokia Imei plain: Product Code: 0573014 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: MG Language Pack: - not available. Failed to read SP data Imei net: Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 [CR1]DCT4PLUS remaining credit: 47 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_ Updating SIMLOCK ...OK Reading Simlock info ... Imei net: Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Phone Type: RH-122 SW version: V 03.70 14-04-09 RH-122 (c) Nokia ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y !failed ! 13 SIM_IO_CTRL_LOOP Y !failed ! 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N passed 30 RF_CHIP_ID N !failed ! 52 KASUMI N passed |
07-31-2010, 05:31 | #5 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | First open handset then wash it with good cleaner then hit under lamp about 30 minutes. Now again connect with box erasse flasher>>>write flash with update file>>>>>>>>write pm >>unlock>>>>>>>ui settings.if need write rpl hope ur problem solved.then if not solve just post here ur phone selftest log.hope we can serve u better |
09-20-2011, 11:36 | #6 (permalink) |
Banned Join Date: Aug 2011 Location: Bhairahawa_Nepal
Member: 1638066 Status: Offline Thanks Meter: 170 | nokia 1600 contact service Phone Type: RH-64 SW version: V 6.41 06-04-07 RH-64 (c) NMP ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y passed 17 TX_IDP_LOOP Y passed 18 TX_IQ_DP_LOOP Y passed 12 SIM_CLK_LOOP Y !failed ! 13 SIM_IO_CTRL_LOOP Y !failed ! 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N passed 30 RF_CHIP_ID N passed |
The Following User Says Thank You to a2zmobile_bhw For This Useful Post: |
09-20-2011, 17:25 | #7 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Quote:
Update initial simlock | |
04-01-2012, 19:05 | #10 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: kerala india
Member: 952533 Status: Offline Sonork: 1001607366 Thanks Meter: 124 | Quote:
04-01-2012, 21:11 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
