09-22-2009, 08:55 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | 1680c-2b WITH ASIC 3162 IS IT SUPPORTED:)- BUS CHECK Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001444D4:DA3BDA66 ASIC type: 11 UEM Imei: 01168100038660 PHONE INFO Code: Version Info: MCU SW version: V 06.22 31-07-08 RM-490 (c) Nokia HW version: 5500 UEM version: 1328 UPP version: 12642 RFIC version: 0500 DSP version: ICPR62_08w24_U LCD version: SUEZ PPM version: V 06.22 31-07-08 RM-490 (c) Nokia MTM Content Pack version: Content: mtm_tmobusa_Aug12th08 V 06.22 31-07-08 RM-490 (c) Nokia Product Info: Production serial number: RJL961864 Product code: 0569974 Module code: 0203969 Basic production code: 0567394 Long production SN: 0 Serial Numbers: IMEI plain: 011681000386601 IMEI spare to net: 0A 11 86 01 00 83 66 IMEI SV to net: 03 11 86 01 00 83 66 30 F8 Other Info: Model : Nokia 1680c-2b (Classic Phone) CS type : GSM850/GSM1900 BSI: 4,6 KOhm Imei net: 01168100038660 Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 CODE CALCULATION Code: IMEI: 01168100038660 Master Code: 3007472372 Network Code: 00101000 #pw + 158 114 504 654 662 + 1 # #pw + 817 211 363 565 665 + 2 # #pw + 763 490 316 147 542 + 3 # #pw + 005 403 551 307 755 + 4 # #pw + 817 801 466 511 050 + 5 # #pw + 255 725 303 340 570 + 6 # #pw + 977 262 027 555 213 + 7 # sahil2000ind |
09-25-2009, 06:37 | #4 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | here successfull log unlock upp id 3162 Code: 2680s-2 unlock done Imei net: 3542070******* Provider: 02 - Esat Digifone-code 7, Country: Ireland Counter: 0/3, 0/10 CONFIG_DATA: 2720200000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 27202F PhoneType:RM-392 SwVersion: V 05.28 05-11-08 RM-392 (c) Nokia MCU file: rm392__05.28.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 3 ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C4ACC0:3B8ADA60 Area [01000000-0101FFFF] erased in 1.125 s Area [01080000-0109FFFF] erased in 1.141 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C4ACC0:3B8ADA60 Area [01000000-0101FFFF] erased in 1.140 s Area [01080000-0109FFFF] erased in 1.157 s Programming ... Programming completed. Completed in 43.390 s Reading Simlock info ... Imei net: 354207******* Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to mbiborna For This Useful Post: |
Flash V171 with C155 flasher - is it possible? | Bogi | Motorola ODM | 11 | 10-21-2006 17:58 |
Help me with 6630,WHY IS IT SO ?Anyone has got one ? | Sparkshfx | Nokia Multimedia | 4 | 05-15-2005 08:01 |
Update CX6V with CX65 firmware. Is it possible? | EchiDNA | S-Gold Based Phones | 8 | 12-11-2004 21:11 |
Solving 4x blinking 3650 with griffin 2_86. Is it possible? | UnlockBR | Griffin | 3 | 10-14-2004 05:42 |
unlock r320 with atr5.3 is it possible? | tucko | Old Ericsson Phones & Sony Phones | 2 | 07-04-2001 03:33 |
