05-18-2010, 09:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642536 Status: Offline Thanks Meter: 22 | 2330c imei change done 100% SwVersion: V 08.20 30-06-09 RM-512 (c) Nokia MCU file: rm512__08.20.mcusw Trying to find patch position ...OK New Imei: 355268036656607 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001615B2:3B8ADA60 Area [01000000-0101FFFF] erased in 0.906 s Area [01220000-0123FFFF] erased in 0.938 s Area [01440000-0145FFFF] erased in 0.907 s Area [014C0000-014DFFFF] erased in 0.844 s Area [01CE0000-01CFFFFF] erased in 0.750 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 29.703 s Phone Type: RM-512 (Nokia 2330c-2) SW Version: V 08.20 30-06-09 RM-512 (c) Nokia Imei plain: 35526803665660-5 Imei OTP: 35524803665660 Product Code: 0581501 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: EH Language Pack: - not available. Imei net: 35526803665660 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN thanks MXKEY Team.... |
The Following 2 Users Say Thank You to mobile_doc For This Useful Post: |
05-18-2010, 10:19 | #3 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 592081 Status: Offline Thanks Meter: 16 | All this error is not mine Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 SERVER: Not a valid IMEI number ( |
05-18-2010, 10:41 | #5 (permalink) |
Member: 642536 Status: Offline Thanks Meter: 22 | re there is a way to do this 1st- unistall new version 2nd- install mx key old version 3.2 3rd- change your computer date to year 2009 4th- flash it with 8.20 5th- go to imei change , write new imei after all these your work will done i have done 2 handsets |
The Following User Says Thank You to mobile_doc For This Useful Post: |
05-18-2010, 11:11 | #10 (permalink) |
Member: 642536 Status: Offline Thanks Meter: 22 | here is logs PhoneType:RM-512 SwVersion: V 08.20 30-06-09 RM-512 (c) Nokia MCU file: rm512__08.20.mcusw Trying to find patch position ...OK New Imei: 356911030050767 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0011489F:3B8ADA60 Area [01000000-0101FFFF] erased in 0.766 s Area [01220000-0123FFFF] erased in 0.766 s Area [01440000-0145FFFF] erased in 0.797 s Area [014C0000-014DFFFF] erased in 0.781 s Area [01CE0000-01CFFFFF] erased in 0.656 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 22.265 s Phone Type: RM-512 (Nokia 2330c-2) SW Version: V 08.20 30-06-09 RM-512 (c) Nokia Imei plain: 35691103005076-7 Imei OTP: 35194903674503 Product Code: 0581501 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: EH Language Pack: - not available. Imei net: 35691103005076 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
05-18-2010, 11:21 | #12 (permalink) |
Member: 642536 Status: Offline Thanks Meter: 22 | how you can say that .... it means all are fake which is done by others and every thing is possible which you are doing well ... my dear friend it is possible and i can do and i give you procedure , try with my procedure , you can solve your problem 100% .... written on stone . |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
ESN Change | OGOMEZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 23:56 |
