Old 12-28-2009, 09:10   #1 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
Arrow 6300 contact service
MX-KEY LOG...................................
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.21 05-11-08 RM-217 (c) Nokia.
Imei plain: 35983501293654-4
Product Code: 0546632
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 359835012936544
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 12-28-2009, 09:39   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
JUST WRITE MODIFIED PM WITH SX4 AUTH
WBR
sahil2000ind
File Type: rar 6300modifyed.rar (794 Bytes, 163 views)
Old 12-28-2009, 09:43   #3 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
Just do sx4 then write modified pm then phone will be ok
Old 12-28-2009, 11:09   #4 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
WBR
sahil2000ind
u beleve that info in mx key is right ??
but its wrong in jaf & ub
in jaf show
CONFIG_DATA: 0000000000000000
then what we do ???
Old 12-28-2009, 11:33   #5 (permalink)
Nesirliler's Avatar
Member: 104393
Thanks Meter: 13
first time do pm auth if writing like that
ad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
you must do rpl service
Old 12-28-2009, 11:36   #6 (permalink)
Nesirliler's Avatar
Member: 104393
Thanks Meter: 13
Connecting to server ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 94.20.58.150
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Old 12-28-2009, 12:05   #7 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
in jaf show
then what we do ???
FROM WHICH SET THIS INFO IS CAN U PLS EXPLAIN MORE.
WBR
sahil2000ind
Old 12-28-2009, 12:53   #8 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
WBR
sahil2000ind
mostly 6300 & 3110 this problem fase
like in mx ke show config data good but in ub & jaf its show conf data 0000000000000
& set in contact servise
i do modified pm with sx4
but same condition
Old 12-28-2009, 12:57   #9 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
Arrow Need the help
MX-key Team PLZ tell me.
How I can use sx4 auth for solve this problem ?
Old 12-28-2009, 21:35   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can't answer this until u show 1 phone
show info log by mxkey and other
br,
Old 12-28-2009, 21:37   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
u can pmm auth/sx-4 by view log each phone or selftest info
must be undesrtanding in log view.
br,
Old 12-29-2009, 01:41   #12 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
hello
first u need 2 make downgrade from version 7.21 to lowest version(vr 7.21 have new firmware protection)
now try making SX4 (u must have right access key,thats mean the superdongle must be valid or seem 2 be valid)
after SX4 authoration done,write any pm have field 1 and 309
another method:
save full rpl backup,rest npc,write full pm,restore ur backup
br
Old 12-29-2009, 04:14   #13 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
br,
ok sir i will post log with screenshot & pm u
Old 12-29-2009, 06:34   #14 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
Reset NPC write Full PM but problem same........
Imei: 35983501293654
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 10400103103A6E569ADFD13A4F75DEC351F3B127
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0538334)... OK
Updating PSN (DQA124026)... OK
Updating HWID (1000)... OK
Updating LOCK ...error 0x0
Updating WMDRM_PD...OK
Certificate programmed successfully !
Product Code: 0538334
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 12-29-2009, 07:30   #15 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Updating RF ...OK
Updating BB ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC verified Ok.
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
can u give this logs with jaf or any other tools
nokia 5220 contact service 6300 contact service urgent please me prakash40 Nokia Hardware & Hardware Repair 5 02-25-2010 09:56
6300 contact service after flash tririval MT-BOX 3 08-16-2007 16:15
6300 contact service ozeracar MT-BOX 1 07-31-2007 19:20
Page generated in 0.23344 seconds with 10 queries
