Old 06-17-2010, 18:27   #1 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
2610b Unlocked success but now not Signal
I have got 2610b with phone restricted the unlock was successful with mxkey but now signal is not given how to solve the problem with mxkey if any solution plz post step by step thanks in advance
this is the log
Phone Type: RH-87 (Nokia 2610)
SW Version: V 07.04a 26-08-08 RH-87 (c) Nokia.
Imei plain: 01168400758765-0
Imei OTP: 01168400758765
Product Code: 0567579
Cellular System: GSM
ASIC ID: 0x3168, type: 11
Ppm Id: MCR
Language Pack:
- not available.
Imei net: 01168400758765
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
The Following 2 Users Say Thank You to Misbahullah For This Useful Post:
Old 06-17-2010, 18:51   #2 (permalink)
Member: 1128573
Thanks Meter: 242
br. when u unlock , phone ask for mcu file same ver. ? or not ask ? how much service provider have in your country ? if more then one, u check one by one sim . if all fail. go reflash phone with same ver. wirte pm. again unlock. then reset all. post the result .
thanks
mahir ashab
Old 06-17-2010, 18:56   #3 (permalink)
Shohel_sst's Avatar
Member: 577653
Thanks Meter: 235
this is the log
Ppm Id: MCR
Language Pack:
- not available.
Counter: 0/3, 0/10
Write 2610 (rh-86) good pm change two filter 100% work tested............
Old 06-17-2010, 20:29   #4 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Angry
This is the right answer.
Br.
Vijendra Saini.
Old 06-21-2010, 12:57   #5 (permalink)
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
how to change filters would you please explain it
Old 06-21-2010, 13:30   #6 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
No no if it is not a hardware problem than it can be only solved through patch file not through pm.I have faced this problem in many dct4 mobiles and only solved through patch file in jaf(Some time hwk failed through patch files).I recomand you to unlock it again through patch file.Search for RH-87 v7.4a patch file.If u failed than tell me i will uplopad it for you.
REgards
Old 06-21-2010, 14:19   #7 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
change filters
write 2610 PM
then it will work for 900Mhz/1800Mhz
Old 06-21-2010, 14:22   #8 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
1. Unlock
2. change filters
3. write pm
4. Enjoy
The Following 2 Users Say Thank You to nadirghazi For This Useful Post:
Old 06-21-2010, 14:37   #9 (permalink)
Member: 520918
Thanks Meter: 8
Talking 2610b to 2610
Unlock with mxkey, change filters and write 2610 good pm
all is well
Old 06-21-2010, 14:49   #10 (permalink)
Member: 1286594
change filters , write pm, unlock with the same mcu file and factory defauld.
@rMaN
Old 06-28-2010, 09:14   #11 (permalink)
Member: 1299025
please help on how to unlock my nokia 2610b imei no 011664001942911
Old 06-29-2010, 13:05   #12 (permalink)
austinejiasa's Avatar
Member: 1149419
Sonork: NIL
Thanks Meter: 58
similar problem,pls help
after unlocking,no network,i tried flashing but it says MCU ID NOT SUPPORTED,and the worst is that the phone cannot even power on now,what should i do
Old 06-30-2010, 03:02   #13 (permalink)
Member: 564436
Thanks Meter: 132
flash with ufs
other eresh then flash with jaf
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.18655 seconds with 9 queries
