Old 01-06-2010, 02:42   #1 (permalink)
milankumardoshi's Avatar
Member: 135200
Sonork: 100.1594691
Thanks Meter: 33
nokia 7210c *****
here is my self test of 7210c i get contact service problem
Phone Type: RM-436
SW version: V 06.51 23-03-09 RM-436 (c) Nokia
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y passed
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N passed
20 BACKUP_BATT N passed
43 LCD N passed
21 LPRF_IF N passed
44 LPRF_AUDIO_LINES N passed
2 CURRENT_CONS N passed
42 RADIO N passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N !failed !
71 BT_WAKEUP N passed
96 HOOKINT N passed
88 TAHVOINT Y passed
101 BTEMP N passed
119 IIC N passed
108 EXT_DEVICE N passed
56 CDSP_SLEEPCLK_FREQ N passed
128 CDSP_SLEEPCLOCK_FREQ N passed
86 CDSP_RF_BB_IF N passed
83 CDSP_RF_SUPPLY N passed
80 CDSP_TX_PLL_PHASE_LOCK N passed
81 CDSP_RX_IQ_LOOP_BACK N passed
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
my phone log
Original Imei: 35931002
Original Product code: 0572571
Bluetooth ID: 00247D289EE9
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 06.51 23-03-09 RM-436 (c) Nokia
Imei plain: 3593100286
Product Code: 0563611
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 3593100
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Connecting to server ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 121.247.94.254
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
SOME ONE PLZ HELP ME I ALSO DID GENSX4 BY MT BOX AND LOST 12 CREDITS BUT AFTER WRITING SX4 RPL STILL I GET CONTACT SERVICE.
Old 01-06-2010, 03:22   #2 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
Bad phones ack, probably SUPER DONGLE_KEY corrupted !
that's y u cant authorize to SX4.
At PRESENT mx key not supporting SD repair.
i think u have to repair security and then sd rebuild .(both need some other tool- credit robbers.)
just check ur private message in box
regards,
NEIL
Old 01-06-2010, 04:32   #3 (permalink)
dharmeshslnk's Avatar
Member: 385162
Thanks Meter: 598
bro try sx4 again may be your internet promblem try again
Old 01-06-2010, 04:48   #4 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
regards,
NEIL
as you can see the log above superdongle key looks ok
so he need to use sx4 auth to write pm on it to remove contact service etc..
if no help simply try other..
Old 01-06-2010, 04:55   #5 (permalink)
Member: 1150025
Thanks Meter: 70
yes just write modified pm
Old 01-06-2010, 06:32   #6 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
Phone Type: RM-436
43 LCD N passed
21 LPRF_IF N passed
42 RADIO N passed
96 HOOKINT N passed
101 BTEMP N passed
119 IIC N passed
my phone log
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 3593100
Counter: 0/3, 0/10
No SX4 Card found.
try again sx4.some time need three or four time.and also check your internet connection.
and write ofcourse a good modified pm
Old 01-06-2010, 06:45   #7 (permalink)
Member: 135200
Sonork: 100.1594691
Thanks Meter: 33
tried with all boxes
[QUOTE=shahinahmed007;5224602]try again sx4.some time need three or four time.and also check your internet connection.
and write ofcourse a good modified pm[/QUOTE
tried sx4 man times on mx jaf and mt but still same problem internet connection is good
also DID GENSX4 BY MT BOX AND LOST 12 CREDITS BUT AFTER WRITING SX4RPL STILL I GET CONTACT SERVICE. plz help.
Old 01-07-2010, 01:37   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
write
HWC NPC and CCC NPC backup from same phone and type.
br,
Old 01-07-2010, 07:39   #9 (permalink)
Member: 135200
Sonork: 100.1594691
Thanks Meter: 33
how to write
Originally Posted by MobileEx-Team View Post
write
br,
i have same phone data how to do wirte plz help
Old 01-07-2010, 07:57   #10 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
http://forum.gsmhosting.com/vbb/showthread.php?t=893189
Old 01-07-2010, 08:04   #11 (permalink)
shimul rahman's Avatar
Member: 855406
Thanks Meter: 41
do with UB box or Mxkey.....
It will be okkkkkkkkkk
Old 01-07-2010, 08:12   #12 (permalink)
Member: 135200
Sonork: 100.1594691
Thanks Meter: 33
but i dont get sx4 autorisztion
Originally Posted by shahinahmed007 View Post
i cannot do sx4 authorisation
Old 01-07-2010, 08:20   #13 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
you have mxkey?
if have please read my post carefully.
sometime need 3 or 4time for sx4. so try again ofcourse you have good internet speed.
and than write a good pm here it is--------http://www.megaupload.com/?d=Y7V6WMUA
Old 01-07-2010, 11:07   #14 (permalink)
Member: 135200
Sonork: 100.1594691
Thanks Meter: 33
I cannot do sx authorization with any box
you have mxkey?
If have please read my post carefully.
sometime need 3 or 4time for sx4. So try again ofcourse you have good internet speed.
and than write a good pm here it is--------http://www.megaupload.com/?d=y7v6wmua
i cannot do sx authorization with any box
Old 01-07-2010, 11:24   #15 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 415
you can use sx4 bypass process with original ufsxhwk. it provides offline solution to write modified pm to phone...
tested many times and works perfect.
Compatible Nokia 7210c Dummy Phone IPMART ipmart WebShop 0 10-25-2008 08:50
Cable (10Pin) Compatible For Nokia 7210C For MT Box IPMART ipmart WebShop 1 09-20-2008 08:57
Cable Compatible For Nokia 7210C For JAF / UFS HWK IPMART ipmart WebShop 0 09-20-2008 08:00
Nokia 7210c Dummy Phone - Original IPMART ipmart WebShop 0 09-05-2008 12:36
Page generated in 0.24809 seconds with 9 queries
