04-24-2010, 09:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | 2630 restart on camera !Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DB633FA3BDA66 ASIC type: 11 UEM Imei: 35418003674205 Flash Imei: 35418003674205 MasterCode: 0403545210 RPL saved to "C:\mobileEx\3.3\data\backup\35418003674205_BACK.r pl" Phone Type: RM-298 (Nokia 2630) SW Version: V 06.82 26-09-08 RM-298 (c) Nokia Imei plain: 35418003674205-6 Imei OTP: 35418003674205 Product Code: 0549372 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 35418003674205 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN camera XXXXXX no dynamic camera configurtion file found Camera Configuration file write failed ! |
04-24-2010, 16:43 | #3 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | need corect dcc file 2630 i need dcc camera file for 2630.i try many file from mx key camera section but problem not salved.plz help me out mxkey with ufs info MCU SW : V 06.82 26-09-08 RM-298 (c) Nokia PPM SW : V 06.82 26-09-08 RM-298 (c) Nokia IA Product : Nokia 2630 Prd.Code: 0549372 Bpr.Code: 0544206 Prod.Sn : IJF690793 HW Vers : 3000 UEM : 1328 UPP : 12642 [3162] RFIC Ver: 0500 DSP Vers: ICPR62_08w27_U LCD Type: SUEZ CAM Prim: XXXXXX (DCC Mismatch) IMEI : 354180-03-674205-6 SL Conf : 001-01-00000000000 SL Prof : 800000000001000-B SL Var : 00553541800367420500 SL Aux : 000B5555 HW Sig : C148189CB30B1A5D Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment and with mxkey config file name XXXXXX when i install it.this error is come Camera Configuration file write failed ! |
04-25-2010, 14:12 | #4 (permalink) | |
Member: 383211 Status: Offline Thanks Meter: 131 | Quote:
09-14-2010, 10:47 | #6 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Shariatpur, Bangladesh. Age: 38
Member: 675369 Status: Offline Sonork: 100.1592503 Thanks Meter: 93 | No need replace any IC, Just write DCC file by MXKEY, Your camera will 100% OK. |
The Following User Says Thank You to helalmahmud For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
