11-07-2009, 09:56 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: from the dark past
Member: 744064 Status: Offline Thanks Meter: 99 | 2630 simlock data corrupted.. Library version: 1.0.0.10913, Date: 05-11-2009 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0051B4E0A3BDA66 ASIC type: 11 UEM Imei: 35292802717095 Phone Type: RM-298 (Nokia 2630) SW Version: V 04.90 14-11-07 RM-298 (c) Nokia Imei plain: 35292802717095-6 Imei OTP: 35292802717095 Product Code: 0549365 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: EJ Language Pack: English,Russian,Ukrainian Imei net: 35292802717095 Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! tried to unlock and write pm but still contact service... |
11-07-2009, 12:22 | #2 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Just Erase The Firmware............ Then Flash It Again With v5.22......... Write Good P.M And Unlock............ All Will Be Fine............ |
The Following User Says Thank You to prince_arsalan For This Useful Post: |
11-07-2009, 21:12 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Quote:
The Following User Says Thank You to GsmUniversal For This Useful Post: |
01-05-2010, 13:21 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: SRI LANKA
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | 2630 57.20 contact service solution Imei net: 35319203788723 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555035555 SIMLOCK_DATA corrupted! UNLOCK WITH MX KEY AFTER PhoneType:RM-298 SwVersion: V 57.20 09-02-09 RM-298 (c) Nokia MCU file: rm298__57.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C91D21:3B8ADA60 Area [01000000-0101FFFF] erased in 1.188 s Area [016C0000-016DFFFF] erased in 1.171 s Area [013E0000-013FFFFF] erased in 1.187 s Area [01480000-0149FFFF] erased in 1.188 s Area [01C20000-01C3FFFF] erased in 1.172 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 41.860 s Reading Simlock info ... Imei net: 35319203788723 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
01-05-2010, 13:22 | #6 (permalink) |
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | 2630 57.20 contact service solution Imei net: 35319203788723 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555035555 SIMLOCK_DATA corrupted! UNLOCK WITH MX KEY AFTER PhoneType:RM-298 SwVersion: V 57.20 09-02-09 RM-298 (c) Nokia MCU file: rm298__57.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C91D21:3B8ADA60 Area [01000000-0101FFFF] erased in 1.188 s Area [016C0000-016DFFFF] erased in 1.171 s Area [013E0000-013FFFFF] erased in 1.187 s Area [01480000-0149FFFF] erased in 1.188 s Area [01C20000-01C3FFFF] erased in 1.172 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 41.860 s Reading Simlock info ... Imei net: 35319203788723 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN [email protected] CLICK THANKS |
2630 sp data corrupt | nyonyo | Cyclonebox | 5 | 11-05-2009 13:18 |
2630 sp data corrupt | nyonyo | Cyclonebox | 1 | 11-05-2009 11:06 |
2630 SL Data Corrupted | jayanandana | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-23-2009 13:32 |
