12-06-2009, 07:30 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Bangladesh
Member: 715924 Status: Offline Sonork: 100.1662616 Thanks Meter: 83 | 2630 ver 57.20 unlock done by Mx key Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23433F BLOCK 2: 1.LOCKED (MCC+MNC): 23486F PhoneType:RM-298 SwVersion: V 57.20 09-02-09 RM-298 (c) Nokia MCU file: rm298__57.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004C1479:3B8ADA60 Area [01000000-0101FFFF] erased in 0.406 s Area [016C0000-016DFFFF] erased in 0.438 s Area [013E0000-013FFFFF] erased in 0.390 s Area [01480000-0149FFFF] erased in 0.407 s Area [01C20000-01C3FFFF] erased in 0.390 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 59.578 s Reading Simlock info ... Imei net: 35521903421554 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following 3 Users Say Thank You to muktadirma For This Useful Post: |
12-06-2009, 07:59 | #3 (permalink) | ||
Product Supporter Join Date: Nov 2008 Location: UnlockBank World
Member: 912688 Status: Offline Sonork: 100.1623116 Thanks Meter: 184 | Why this data changed Quote:
12-07-2009, 05:22 | #6 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | CONFIG_DATA: 2343300000000000 <-- this is the MCC+MNC for Orange UK (23433000) CONFIG_DATA: 0010100000000000 <-- this is if the phone is NOT LOCK....( All Operator ) |
12-09-2009, 09:12 | #8 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | it is very simple.however i explain it more ....first you get 2630 v57.20 firmware and install it.....after that connect phone with fbus or easy cable....now connect phone to ufs/jaf . open mxkey 3.3 rev 1.x go to service tab and then imei and security.....select simlock and click on update splock....it will ask you for the mcu file....select mcu 57.20......that`s all you have done.......remember to use above mentioned version of mxkey..not older or crack etc.... |
01-09-2010, 13:49 | #9 (permalink) |
Freak Poster Join Date: May 2005 Age: 53
Member: 143281 Status: Offline Thanks Meter: 17 | successfully unlocked... Code: Imei net: 35xxxxxxxxxxxx Version: SIMLOCK SERVER Provider: Tesco Mobile, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341000000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23410F PhoneType:RM-298 SwVersion: V 57.20 09-02-09 RM-298 (c) Nokia MCU file: rm298__57.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00057B0A:3B8ADA60 Area [01000000-0101FFFF] erased in 1.125 s Area [016C0000-016DFFFF] erased in 1.141 s Area [013E0000-013FFFFF] erased in 1.125 s Area [01480000-0149FFFF] erased in 1.141 s Area [01C20000-01C3FFFF] erased in 1.140 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 38.969 s Reading Simlock info ... Imei net: 35xxxxxxxxxxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
Semens c65 unlock done by mx-key. | bsat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 17 | 02-15-2011 11:16 |
2630 ver 57.20 unlock done by Mx key | anvaranvar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-21-2010 15:51 |
2630 ver.57.20 unlock ok universalbox | shahid41 | Universalbox | 1 | 12-02-2009 11:55 |
2630 vers 57.20 unlock problem | ..::GsmHelp::.. | Cyclonebox | 5 | 10-18-2009 17:47 |
2630 ver 57.20 unlock ok universalbox | shahid41 | Universalbox | 0 | 09-14-2009 10:10 |
