05-08-2010, 10:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | 3110c contact service SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: *********** Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: ************* Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to naveed ali For This Useful Post: |
05-08-2010, 10:49 | #2 (permalink) |
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | Phone authenticated to SUPERDONGLE already. Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 1.656 s |
05-08-2010, 17:05 | #8 (permalink) |
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2850020E0CD97E56555C984A738F3FD5AE804CE7 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Begin Certificate Request ... [SOAP-ENV:Server] SOAP-ERROR: Encoding: string 'CERT [\xff...' is not a valid utf-8 string [SOAP-ENV:Server] SOAP-ERROR: Encoding: string 'CERT [\xff...' is not a valid utf-8 string [SOAP-ENV:Server] SOAP-ERROR: Encoding: string 'CERT [\xff...' is not a valid utf-8 string |
05-08-2010, 17:53 | #9 (permalink) |
Junior Member Join Date: Nov 2007 Location: thainguyen
Member: 633136 Status: Offline Sonork: [email protected] Thanks Meter: 5 | IMEI net: *************.chinh la o day ban oi |
05-08-2010, 19:51 | #12 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | backup rpl rest npc go to pm click erase pm writ rpl then click recover cert repair sd (you will get rpl to repair sim & sd) go to pm >click SUPER SD AUTH and writ pm fullfactory&format |
05-08-2010, 20:56 | #13 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan
Member: 386511 Status: Offline Thanks Meter: 305 | Added, FREE BB5 Certificate Recovery to reflect the CERT validation features ~ This will make restore CCC,HWC or VARIANT by product code from server database. Button located to [IMEI & Security->Recover CERT] what is that functions use for? this functions for repair SECURITY_TEST failed or contac retailer this case for repair CCC,Hw or variat by product code where you can find that functions in mxkey latest software? Button located to [IMEI & Security->Recover what will happen if still get error Updating CMT HWC ...failed check certificate validations Added, BB5 Certificate Validation ~ Usefull to identify SECURITY_TEST problem specially if SUPERDONGLE is valid where can find that buton? Button located to [Phone Test->Various] all operations need to use internet connections for working with mxkey server please make sure your internet working perfectly and running well PS: Dont forget to backup all(rpl etc) before do this way wish you luck br |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-11-2000 03:43 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
