03-10-2010, 15:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: THE END Age: 40
Member: 195225 Status: Offline Thanks Meter: 94 | 3110c contact service after repaire sd Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35602903558689-9 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356029035586899 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-10-2010, 15:05 | #2 (permalink) | |
No Life Poster Join Date: Oct 2009 Age: 37
Member: 1149013 Status: Offline Thanks Meter: 247 | Quote:
write pm & sx4 ur problem solve .................. | |
The Following User Says Thank You to Master Software For This Useful Post: |
03-10-2010, 15:07 | #4 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | Wtit pm.1 and 309,with super sx4 authetication........... |
The Following User Says Thank You to rasheedc007 For This Useful Post: |
03-10-2010, 15:12 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | 1:write pm 2:repair sd 3:super sd auth 4:write pm 1 to 309 i hope your problem solved |
The Following User Says Thank You to meeza_84 For This Useful Post: |
03-10-2010, 15:16 | #7 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Quote:
SUPER SD AUTH WRITE PM 1@309 SCAN AGAIN.....SEE Result.. Br,. Rhyan777 | |
The Following User Says Thank You to Rhyan777 For This Useful Post: |
03-10-2010, 15:23 | #8 (permalink) | |
Freak Poster Join Date: Apr 2009
Member: 1003310 Status: Offline Thanks Meter: 28 | Quote:
The Following User Says Thank You to realtech For This Useful Post: |
7210c contect servic after repair SD | GSM_IMRAN | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 03-11-2010 12:42 |
6120c contact service after calculated sd.. | arabie | Universalbox | 22 | 01-28-2010 10:50 |
3110c contact service after rpl | smartengghelp | Gsmfather The Wholesale Unlocking Database | 2 | 03-11-2009 07:47 |
