01-11-2013, 01:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: philippines
Member: 1501033 Status: Offline Thanks Meter: 35 | 3110c flash cnt with wrong file need your help thanks in advance |
01-11-2013, 02:28 | #3 (permalink) |
Member: 1501033 Status: Offline Thanks Meter: 35 | [QUOTE]what is the condition of the phone now?[QUOTE] thanks sir for reply when i flash it to the right files the phone will on then off and nothing what i shall do |
01-11-2013, 05:46 | #7 (permalink) |
Member: 1501033 Status: Offline Thanks Meter: 35 | thanks for helping me sir problem solved EM1 ID: 00000353 PUBLIC ID: 1A000203F87E7E565598FB223945F181BA5151AB ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Processing MCU file: rm237__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.49 MB Supported Ids: 0103192101001101, 010C192101001101 Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00020000-0007FFFF] CMT FLASH,NOR area [00080000-000DFFFF] CMT FLASH,NOR area [00100000-001FFFFF] CMT FLASH,NOR area [00200000-0031FFFF] CMT FLASH,NOR area [00320000-0105FFFF] CMT FLASH,NOR area [01060000-01067FFF] CMT FLASH,NOR area [01068000-0107FFFF] erased in 1 min 15.953 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 11.613 s Processing PPM file: rm237__07.30.ppm_b [BB5,BB5 ALGORITHM] size: 3.20 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 4.62 MB CMT FLASH,NOR area [01080000-0151FFFF] erased in 21.500 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 13.048 s Processing CNT file: rm237__07.30.image_ora_pl_games [BB5,BB5 ALGORITHM] page size: 64 K size: 4.57 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 10.75 MB CMT FLASH,NOR area [01520000-01FDFFFF] erased in 42.047 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 18.655 s Total time for flashing process(boot+erase+write) was 4 min 10.099 s Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35196xxxxxxxxxxx Product code: 0514947 Battery voltage: 4743 mV, current: 98 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351963038914366 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN HTI Flasher Interface (WinUSB) disconnecte |
