11-10-2010, 05:09 | #1 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: Philippines
Member: 557796 Status: Offline Thanks Meter: 187 | 3110c no power,i flashed it on Mxkey but it shows this (hardware problem, closed) need help about this 3110c no power problem... i flashed it into Mxkey but it goes all okey except for this Quote:
has anyone have an idea how to fix this mobile?..... | |
11-10-2010, 05:15 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | try with repair simlock data .. & also try repaire downgrad option |
The Following 2 Users Say Thank You to sneha For This Useful Post: |
11-10-2010, 07:37 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | Quote:
The Following User Says Thank You to rajeshlehal For This Useful Post: |
11-10-2010, 07:54 | #5 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 45
Member: 132735 Status: Offline Thanks Meter: 88 | the switch is ok....because the phone vibrates when he tuned it on... back up your crt then flash the erase bin..after erasing done...flash again then restore crt... post result. br |
The Following User Says Thank You to smorbe For This Useful Post: |
11-11-2010, 07:08 | #6 (permalink) |
Member: 666540 Status: Offline Thanks Meter: 354 | Yes you are right on/off is ok coz vibrator is working while press the on/off, now check light & display , in mxkey it shows Info I think ur phone is powering on but not showing light & display.....I had that kind of problem also I found fault in light & display both problems.... |
11-11-2010, 07:51 | #7 (permalink) |
Member: 557796 Status: Offline Thanks Meter: 187 | problem solved... i just replaced LCD connector on the main board..... it's a hardware problem........ thread closed...... |
The Following User Says Thank You to =Deftones= For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
