02-07-2010, 16:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: In My ThinkPad
Member: 756569 Status: Offline Thanks Meter: 185 | 3110c SD Problem Your Attention Please New Solution for Nokia 3110c after repair SD key Security Test Failed Dear All, I have try Manole solution first and second solution but no more change at my nokia 3110c, always get not success for SUPER SD Auth. And I have try tested use UFS box with HWK original as follows: 1. Make SX4 ByPASS 2. Write full PM from working Phone and do not skip all areas 3. Write Backup Certificate and u will get provider not found 4. Closed USF box 5. Connect MXKEY used UFS box 6. Repair SIMLOCK 7. Repair SD 8. Used SUPER SD Auth 9. Write FULL PM I was do this and all ok but no network, i was try with 2 pm but same, what is wring. Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35196303216346-5 Product Code: 0554219 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-11-12T10:00:50Z SW Version: 07.21 Variant Version: 007 ProductProfile: RM237_0554219_07.21_007.spr Simlock: 0554219_simlock.bin Imei net: 351963032163465 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-08-2010, 06:59 | #2 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
try selftest and post here . br, | |
02-08-2010, 15:36 | #3 (permalink) |
Member: 756569 Status: Offline Thanks Meter: 185 | Sir, Thanks for your ans. But network Was OK. only problem is off it salf after some time.now do't off, but no network. Help me please. Log From Ufs MCU SW : V 07.21 05-11-08 RM-237 (c) Nokia. PPM SW : V 07.21 05-11-08 RM-237 (c) Nokia. S Prd.Code: 0554219 Bpr.Code: 0542523 Prod.Sn : 7G0316980 HW Vers : 2000 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 17211721 DSP Vers: ICPR61_08w10 IMEI : 351963-03-216346-5 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland Log From MX KEY Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 18E00119F2737E56A6008980A09F7EFE8A25D7AE ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Original Imei: 35196303216346 Original Product code: 0550542 Bluetooth ID: 00247D6BF405 Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35196303216346-5 Product Code: 0554219 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-11-12T10:00:50Z SW Version: 07.21 Variant Version: 007 ProductProfile: RM237_0554219_07.21_007.spr Simlock: 0554219_simlock.bin Imei net: 351963032163465 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
3110c sd repair prbolm | infinitymobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 09:31 |
3110c SD not repair | sonu arya | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-04-2010 15:56 |
can i repair 3110c SD data by genSX4 button | TheFoXMK | MT-BOX | 2 | 11-30-2009 23:32 |
