03-06-2010, 14:43 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | 3110c usb flashing error is there any solution ? Code: Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 04B0011136467C56D3417D98571BE4FF66C31C8F RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 34.875 s when i try to flash this set with fbus then i get this error .. Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 04B0011136467C56D3417D98571BE4FF66C31C8F ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.781 s CMT NOR area [000006C0-0001FFFF] erased in 0.172 s CMT NOR area [00020000-0007FFFF] erased in 2.484 s CMT NOR area [00080000-000DFFFF] erased in 0.203 s CMT NOR area [00100000-001FFFFF] erased in 0.344 s CMT NOR area [00200000-0031FFFF] erased in 0.375 s CMT NOR area [00320000-0105FFFF] erased in 3.157 s CMT NOR area [01060000-01067FFF] erased in 0.187 s CMT NOR area [01068000-0107FFFF] erased in 0.172 s Flash programming ... CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written. Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00204400, Result: 0010 Flashing terminated with error(s) in 45.906 s RX Buffer: C7012D0103CD000010000000F172 |
03-06-2010, 21:50 | #4 (permalink) | |
Freak Poster Join Date: Apr 2009
Member: 1003310 Status: Offline Thanks Meter: 28 | Quote:
If any body succeeded with this option pls comment http://forum.gsmhosting.com/vbb/showthread.php?t=940868 | |
03-07-2010, 06:00 | #5 (permalink) | |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
after getting this i do press power on or insert the charger , then only i can get this --- Code: [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 04B0011136467C56D3417D98571BE4FF66C31C8F RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 34.875 s what could be the problem ? i have also pasted the bus check ... | |
03-07-2010, 06:56 | #7 (permalink) | |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | re Quote:
plz need correct way............... | |
03-07-2010, 13:03 | #12 (permalink) |
Registered User Join Date: Aug 2009 Location: wooooooL
Member: 1092636 Status: Offline Thanks Meter: 43 | Library version: 1.0.0.7687(12-02-2010), 1.0.0.12183(16-02-2010) Processing file: rm146__07.20.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.56 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Phone must be switched off, put USB cable to the phone. Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 22000110AC2F6B56CE326F6CFA25CA0BF24CD6B4 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 333AF9BE [ADL] Verifying communication to device OK. Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.390 s CMT NOR area [000006C0-0001FFFF] erased in 0.030 s CMT NOR area [00020000-0007FFFF] erased in 1.142 s CMT NOR area [00080000-000DFFFF] erased in 0.080 s CMT NOR area [00100000-001FFFFF] erased in 0.210 s CMT NOR area [00200000-0031FFFF] erased in 3.445 s CMT NOR area [00320000-0105FFFF] erased in 40.198 s CMT NOR area [01060000-01067FFF] erased in 0.391 s CMT NOR area [01068000-0107FFFF] erased in 0.020 s Flash programming ... CMT PAPUBKEYS: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13 (Rap Certificate 30 v1) written. Programming completed in 1 min 35.017 s Processing file: rm146__07.20.ppm_x as PPM [BB5,BB5 ALGORITHM] size: 5.26 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 5.50 MB CMT NOR area [01080000-015FFFFF] erased in 16.514 s Flash programming ... Programming completed in 35.151 s Processing file: rm146__07.20.image_x_black as CNT [BB5,BB5 ALGORITHM] page size: 64 K size: 5.44 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 9.87 MB CMT NOR area [01600000-01FDFFFF] erased in 29.873 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 36.002 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 5300 XpressMusic USB Generic, ID: 186EFF93 [ADL] Verifying communication to device OK. Flashing completed in 5 min 4.297 s Phone Type: RM-146 (Nokia 5300) SW Version: V 07.20 23-10-08 RM-146 (c) Nokia. Imei plain: 35555001150792-3 Product Code: 0545297 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355550011507923 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 5 min 8.634 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.861 s FULL FACTORY... OK done ......... |
3110c usb flashing error in cnt plzz help me | goverdhan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-20-2010 13:22 |
3110c usb flashing error ? | gsmsikar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-22-2010 14:59 |
3110c usb flashing need help | milandhal | Nokia Hardware & Hardware Repair | 5 | 12-24-2008 12:47 |
3110c usb flashing successful in MT-BOX | rkinfo_imran | MT-BOX | 0 | 11-27-2007 23:35 |
3110c usb flashing using phoenix???? | Siemens man | MT-BOX | 3 | 07-05-2007 19:16 |
