11-11-2009, 14:54 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: anywhere
Member: 548078 Status: Offline Thanks Meter: 80 | 5130 contact service Version Info: MCU SW version: V 06.65 01-04-09 RM-495 (c) Nokia HW version: 2000 RFIC version: 06540601 DSP version: ICPR72_09w03 LCD version: SEIKO PPM version: V 06.65 01-04-09 RM-495 (c) Nokia AA BT MCM version: 2222-143C Retu version: 16 Tahvo version: 22 Content Pack version: Content: aa_blu V 06.65 01-04-09 RM-495 (c) Nokia Product Info: Production serial number: IIN757806 Product code: 0577793 Module code: 0204024 Basic production code: 0567772 Long production SN: 0 Serial Numbers: IMEI plain: 355212038216XXXXX IMEI spare to net: 3A 55 12 02 83 12 56 07 IMEI SV to net: 33 55 12 02 83 12 56 37 F2 Other Info: Model : Nokia 5130c-2 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 4.6 KOhm SIMLOCK_DATA corrupted! any idea of this problem. |
11-11-2009, 15:13 | #2 (permalink) | |
Member: 548078 Status: Offline Thanks Meter: 80 | Quote:
Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 23300102A2717D565F21E39185EC4DFB4FBFA2DC ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35521203821657 Original Product code: 0571943 Bluetooth ID: 0025CFAF9AC2 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35521203821657-0 Product Code: 0577793 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! | |
11-11-2009, 15:16 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Syria ♪♫ Tartus Age: 47
Member: 299401 Status: Offline Sonork: facebook:Ahmad Majzoub Thanks Meter: 233 | if u have mx- key or cyclon u can make it by repair sl.... but if SIMLOCK_DATA corrupted! you need new rpl br, Last edited by disel center; 11-11-2009 at 15:26. |
11-11-2009, 15:18 | #4 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Quote:
SUPERDONGLE_KEY invalid! So u need ask2rpl solution | |
11-11-2009, 15:24 | #5 (permalink) |
Junior Member Join Date: Jul 2008
Member: 813199 Status: Offline Sonork: irshad Thanks Meter: 2 | please i need a help from you,i want you to calculate and give me the unlock codes for my blackberry 8900,locked to usa t-mobile,this the imei:353471039209875.please this my e-mail id [email protected] ..(00919633001001) |
11-11-2009, 15:26 | #6 (permalink) |
Member: 813199 Status: Offline Sonork: irshad Thanks Meter: 2 | First Update flishfile... Jaf full flash ... Factory Set & Unlock Next ..JAF_Nokia_BB5_and_BB5Plus_201_FREE_by_Zulea...Ph one info & Unlock Your mobile 100% ok... Next try... BB5 CONATCT SERVIVCE,TRUN OFF PROBLEM,IMEI REPAING SIMPLE GUIDE HOW TO CHECK AND HOW SOLVED THIS PRO BB5 CONATCT SERVIVCE,TRUN OFF PROBLEM,IMEI REPAING SIMPLE GUIDE HOW TO CHECK AND HOW SOLVED THIS PROBLEM SEE CONNECT JAF 1)SELECT BB5 TAB 2)MARKED SELF TEST OPTION 3)USE SERVICE BUTTON  THIS TIME APPER NEW WINDOW NEXT USE RUN ALL BUTTON(RED MARKED) SEE BLUE MARKED AREA  Security===passed Simlock====passed *********************** conact service handsets show (Security===failed) SOLUTION:::::upload pm how to upload pm? here video manual Download Link http://www.gsmfilehosting.com/sztg9vb55v0l.html some times Security===passed,but Simlock====failed how to check sim lock area damage or not?????? connect jaf then use info button see this Configkey –FFFFFFFFFFFFF PROVIDER - unknown security area damaged handsets show this error how to repair this?with out ASK TO RPL service use BB5 king then use UNLOCK option BB5 king FIX THIS PROBLEM BUT ONE THINK SOME TIME PHONE TRUN OFF BEFOR 10 MINUTES THEN U MUST DEPEND ASK TO RPL SERVICE HOPE TO READ ASK WITH JAF ASK FILE ************************* IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 11 F5 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN *************************** THIS PHONE WORKING PREFECTLY BUT TRUN OFF BEFOR 10 MINUTES PROBLEM====RPL DAMAGED SOLUTION===DEPEND ASK TO RPL SERVICE |
The Following 2 Users Say Thank You to irshad09 For This Useful Post: |
11-11-2009, 21:33 | #9 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | u need new calc rpl but, u can fix ur phone now until u can get new rpl when nokia server work again some new models with hash 9DDB accept repaire by rest npc only watch dog will not work but phone will restart some times after some hour cause imei fault(check sum) try & post RAPS_V3.03-PA_SL2 CPU * 3600 slide * 5220 XpressMusic * 7210 Supernova * 7310 Supernova * 7610 Supernova * 7510a * 5130C br |
11-12-2009, 05:00 | #10 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | @moldovan check this link http://forum.gsmhosting.com/vbb/show...33#post4817033 and this link too http://forum.gsmhosting.com/vbb/showthread.php?t=839940 |
The Following User Says Thank You to Chevka For This Useful Post: |
11-12-2009, 06:45 | #12 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MUSLIMS NOT A TERRIORST Age: 46
Member: 1016083 Status: Offline Thanks Meter: 103 | dear brother more time i got mobile nokia 5130 in contact service.but its sl3.and not possible yet.we have 1 solution u take ur rplback up then make a blank rpl.ur mobile will 1234561234?.its IMW showing.now u can see ur mobile is ok.thats mean ur rpl data is demage.take a new rpl.its solution.plz request with other members to post here . |
11-20-2009, 04:23 | #15 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Nepal (Dr.Mobile) Age: 37
Member: 724757 Status: Offline Sonork: 100.1627486 Thanks Meter: 16 | plz help me Using device: UFS_USB V2.8 (c) SarasSoft 2007. RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 2020010362A10154C05D8C45DA1A79DC6223AC2D ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 002F - 0000 0121 [AMD S29NS256N,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: EA424306455C103E3853B304DD1BC0E10F839FBC Original Imei: 35554701430720 Original Product code: 0551674 Bluetooth ID: 001BAF069280 Phone Type: RM-78 (Nokia 6288) SW Version: V 06.43 30-03-07 RM-78 (c) Nokia Imei plain: 35554701430720-2 Product Code: 0551674 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei: 355547014307202 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF how to repairing WD timer enabled, phone will reboot itself after 3 min. plz help me ..................................: eek: |
nokia 5130 contact service | burhani mobile | Nokia Hardware & Hardware Repair | 165 | 12-02-2012 12:27 |
5130 contact service (ANSWERED) | vishal123123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-10-2011 11:05 |
5130 contact service data link | snowkp | Nokia Base Band 5 ( BB-5 ) | 40 | 07-25-2011 09:19 |
nokia 5130 contact service | bombayteji | Nokia Hardware & Hardware Repair | 8 | 06-06-2010 13:01 |
i need help for 5130 contact service | chronic | Nokia Base Band 5 ( BB-5 ) | 6 | 07-24-2009 10:23 |
