03-23-2012, 18:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | 5233 no call MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 21600106CE96005267B6C9D82FFBAA37A3119CEF ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.48.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.48.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Original Imei: 35338504XXXXX0 Original Product code: 059B126 Bluetooth ID: 20D607B1FB9A SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-625 (Nokia 5233) SW version: V ICPR72_09w36.16 02-12-09 RM-625 (c) Nokia ApeCoreSw: V 12.1.092 Imei plain: 35338504XXXXX0-3 Product code: 059B126 Battery voltage: 4651 mV, current: 148 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35338504XXXXX03 Version: SIMLOCK SERVER Provider: Telesc Cel , Country: Brazil Counter: 0/3, 0/10 CONFIG_DATA: 7240500000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=72405F [Brazil-Telesc Cel ] BLOCK2: 1=CLOSED(MCCMNC), DATA=72405F [Brazil-Telesc Cel ] Phone Type: RM-625 SW version: V ICPR72_09w36.16 02-12-09 RM-625 (c) Nokia ID Test name Startup Result 88 TAHVOINT Y passed 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 20 BACKUP_BATT N passed 42 RADIO N passed 96 HOOKINT N passed 101 BTEMP N passed 8 MBUS_RX_TX_LOOP Y !no signal 119 IIC N passed 117 DIGIMIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 85 CDSP_TX_IQ N passed 74 CDSP_TXC_DATA N passed 79 CDSP_RX_PLL_PHASE_LOCK N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 81 CDSP_RX_IQ_LOOP_BACK N passed 77 CDSP_GSM_TX_POWER N !unknown(14 0) - 21 LPRF_IF N !no signal 22 CAMERA_IF N !no signal 5 CAMERA_ACCELERATOR N !no signal 44 LPRF_AUDIO_LINES N !no signal 59 MAIN_LCD_IF N !no signal 60 TOUCH_STUCK N !no signal 71 BT_WAKEUP N !no signal 103 TOUCH_IF N !no signal 104 ACCEL_IF N !no signal 113 LCD_CONTROLLER N !no signal 49 VIBRA N !not ready 91 USB_LOOP N !unknown(8 0) - 42 RADIO N passed |
03-23-2012, 21:09 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. your problem is: 77 CDSP_GSM_TX_POWER N !unknown(14 0) - in your self test means hardware, so clean network terminal & check for water logs near network section, if ok & not solve then do as in image for all TX problem. |
My 6150 (5.23) No network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-31-2001 15:56 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
Nokia 6110 without net. couldnīt call 911 either! | DennisT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-09-2000 11:37 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
