04-11-2012, 07:57 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,694 | 5233 rm-625 flashing problem (SOLVED) |
04-11-2012, 15:19 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. have you try this? if not then try it & will get the answer. (then also a small answer) it will make you stop playing with firmware versions. |
04-11-2012, 15:40 | #5 (permalink) |
Member: 772651 Status: Offline Thanks Meter: 1,694 | i tried but nothing happend .. as i said that i have flashed it with version 51.9.002 .. then i tried to find out the flash file exactly by its product code and i got files of version51.1.002_001 .. now this means if i flash this set again with flash files found against its product code that means i am downgrading it .. please suggest what to do |
04-11-2012, 16:05 | #6 (permalink) |
Member: 772651 Status: Offline Thanks Meter: 1,694 | logs by fbus Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: Using device: HTI, FW ver: 00.50, SN Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 19E00009D6AB00527686339B7F66587AA3120B53 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.48.1 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 10.48.1 revision: 2.0 size: 0x84B10 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Processing MCU file: RM-625_51.9.002_prd.core.C00 [BB5,XSR 1.6] size: 95.02 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 2 min 18.563 s Processing PPM file: RM-625_51.9.002_prd.rofs2.V25 [BB5,XSR 1.6] size: 26.50 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 35.50 MB CMT FLASH,MuxOneNAND area [06DE0000-0915FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 40.203 s Processing CNT file: RM625_51.9.002_002_U549.uda.fpsx [BB5,XSR 1.6] size: 23.16 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 36.125 s Total time for flashing process(boot+erase+write) was 3 min 45.688 s no response from phone there come local mode on screen logs Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: Using device: HTI, FW ver: 00.50, SN: Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 19E00009D6AB00527686339B7F66587AA3120B53 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.48.1 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 10.48.1 revision: 2.0 size: 0x84B10 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Reading CMT NPC (0x168 bytes). Imei: 35626404473631 NPC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35626404473631_NPC.rpl" Erasing CMT NPC ... OK Prog.status for Asic CMT ... NAND: OK Applying BB5 SW Downgrade patch ... Reading signatures ...OK. PM backup saved to "C:\mobileEx\3.5\data\backup\35626404473631_20120411202844_308.1.PM" ERROR: BB5 SW Downgrade patch failed ! CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 19E00009D6AB00527686339B7F66587AA3120B53 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.48.1 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 10.48.1 revision: 2.0 size: 0x84B10 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Updating CMT NPC ...OK Prog.status for Asic CMT ... NAND: OK |
04-11-2012, 16:15 | #7 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. NAND: Status reported bad blocks. so give some heat to flash ic & again flash with latest firmware. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
04-11-2012, 16:32 | #8 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Underground
Member: 1317565 Status: Offline Thanks Meter: 61 | As i've seen in this furom your not the one who face this kind of problem in N5233 after flash, phone is not turning ON. not only in mxkey section also in other nokia tool.. DO SELFTEST or follow what zuberchowdhry said you can also check this one http://forum.gsmhosting.com/vbb/f148...-here-1250036/ |
The Following User Says Thank You to PedaLBoard For This Useful Post: |
04-11-2012, 20:16 | #11 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | take full back up of rpl, sim lock and full pm...the do full erase then flash with any lower version of the same product code i.e. printed on the back label of ur mobile and write back rpl and pm and post results |
04-12-2012, 05:34 | #13 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
Your phone will be fixed, by full erase - reflash method. This only possible if you have good rpl backup for that phone. | |
04-12-2012, 07:06 | #14 (permalink) | |
Member: 772651 Status: Offline Thanks Meter: 1,694 | Quote:
while flashing automatically rpl backup is saved .. is this rpl backup enough or need to take full rpl backup .. because when i m trying to take rpl backup i get error message phone is not responding .. | |
04-13-2012, 18:31 | #15 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,540 | Quote:
what i advise you that you do not need to erase you mobile just go ahead and flash it with version against its product .. your mobile will be alive .. good luck and post the reply Br. Mehmood Riaz | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
