12-16-2012, 10:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: in iOs
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | 5310 auto off in 10min Flash With Latest Vershion No Board Water Damage Remove speaker Change Steel Frame MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C085E9AF Using device: HTI, FW ver: 00.50, SN: 0000E7D4 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 29F00114F864025460DB67492A7176400A94D736 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D TransmissionMode: DDR&TX2 Selected firmware certificate matched. Original Imei: 35956201268361 Original Product code: 0557203 Bluetooth ID: 001E3B412149 SIMLOCK PA identifier: [0] PA_SL2 Phone type: RM-303 (Nokia 5310 XpressMusic) SW version: V 09.42 07-11-08 RM-303 (c) Nokia Imei plain: 35956---------- Product code: 0557203 Battery voltage: 4767 mV, current: 14 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) Camera config: NIMMIIIIRRFF06150018, ver: 002.005 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359------------ Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Self Test Phone Type: RM-303 SW version: V 09.42 07-11-08 RM-303 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 43 LCD N passed 21 LPRF_IF N !not ready 44 LPRF_AUDIO_LINES N !not ready 2 CURRENT_CONS N !not ready 42 RADIO Y passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N !not ready 96 HOOKINT N !not ready 88 TAHVOINT Y !not ready 56 SLEEPCLK_FREQ N passed 101 BTEMP N passed 107 BT_SLEEP_CLK N !not ready 32 AMB_LIGHT_SENSOR N !not ready 119 IIC N !not ready 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 81 CDSP_RX_IQ_LOOP_BACK N passed 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) What This Problem ????????????????? |
12-16-2012, 11:20 | #2 (permalink) | |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Quote:
All Logs Is valid Now tack Action u take Backup rpl or u need to full erase flash set then restore rpl THen Check set an post result. BR Vikash | |
12-16-2012, 14:36 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Logs seems to be OK, Try change LCD & Camera, If not solve, then try to Erase Phone, Step here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ BR, ZUBER |
12-16-2012, 16:01 | #4 (permalink) | |
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | Quote:
Change Display And Remove Camera But No Luck Few min Automatic Going To Hang On Blue Screen | |
12-16-2012, 20:28 | #7 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Even if your PCB looking fine then also Waterlogged, may be. Check properly with Magnifying Glass, whether Display Connector damaged with Water, Many times resolve this type of problem. BR, ZUBER | |
12-18-2012, 19:18 | #9 (permalink) | |||
Combo IC Problem When Little Heat On IC Working After Same Little Shake Now OK Thanks For Support | |||
