Old 04-24-2011, 07:00   #1 (permalink)
*shohel*'s Avatar
Member: 537394
Thanks Meter: 19
Thumbs up N8 secruity test failed (ANSWERED)
how to solved my problem mx-key ?why can't solution mx-key team
we know mx-key team at first latest solution
Phone Type: RM-596 (Nokia N8-00)
SW Version: V 92PS1_10w46.9 01-03-11 RM-596 (c) Nokia
Imei plain: 356...........................
Battery voltage: 4617 mV, current: 74 mA
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356..................
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 04-24-2011, 07:32   #2 (permalink)
*shohel*'s Avatar
Member: 537394
Thanks Meter: 19
i have need npc data and good rpl file pls upload rm-596 rpl file
Old 04-24-2011, 07:37   #3 (permalink)
Member: 462076
Sonork: 100.1586314
Thanks Meter: 307
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
first backup full rpl...
then try to auth pm & write pm..
ur problem will be solved
no need of rpl data
Old 04-24-2011, 07:39   #4 (permalink)
*shohel*'s Avatar
Member: 537394
Thanks Meter: 19
your solution isn't right br .u know n8 cpu rapu11 not rapido br..
understand ?
Old 04-24-2011, 07:40   #5 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
no solution yet with mx key.becoz when you click ppm auth mx key gives u error range check error . plz mx key team update all hash ppm auth and hash calc
Old 04-24-2011, 08:04   #6 (permalink)
Nesirliler's Avatar
Member: 104393
Thanks Meter: 13
Frend Server is under maintace wail ALIM and MANOLE Working tomorow new relase will
Old 04-24-2011, 20:00   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
pmm auth has nothing to do with phone hash.
shohel bhai,
- do not load any pm, mark load RFBB from server. click PMM auth. click write after auth is done.
- if problem still remain, attach your rpl here.
The Following 3 Users Say Thank You to gbluez For This Useful Post:
Old 04-25-2011, 12:00   #8 (permalink)
DD ELECTRONICS's Avatar
Member: 1338815
Sonork: DD ELECTRONICS
Thanks Meter: 58
use load rf bb data option & write 1 to 309 pm solved
only Test zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-29-2000 21:43
Has someome tested this software Nokia New Series Tool? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-20-2000 16:39
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-01-2000 23:47
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.20144 seconds with 9 queries
