06-28-2012, 15:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: ..:: GSM-Forum ::..
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | 5800 After Write PM File SECURITY_TEST failed! First Phone Network Problem Then Try To Super Sd Auth and Write 1-309 PM File After Show SECURITY_TEST failed! After Phone Only Nokia Then Wight Off Here is The Phone Log : Phone type: RM-356 (Nokia 5800 XpressMusic) SW version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia ApeCoreSw: V 60.0.003 Imei plain: 35800900033001-0 Product code: 0559408 Battery voltage: 4434 mV, current: 189 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358279030830010 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN How to Solve SECURITY_TEST failed! Problem |
06-28-2012, 17:15 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. 1st Very Important that BB5 Phone No Network nothing to have with PM File. 2nd For Security Test Failed: Go to Service Tab>Click Load from File>go to address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Click RM-356 PM, now click Repair SD & click no to Pop Up Window for RFBB, now Click Write Button & Buscheck you will see the positive Result. BR, Zuber Chowdhry |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
06-29-2012, 07:27 | #5 (permalink) | |
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | 5800 After Write PM File SECURITY_TEST failed! Quote:
I Try This Steps But After Same Problem Any Other Way ....! | |
06-29-2012, 07:42 | #6 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | bor use to good pm file 5800.RM-356.rar - 4shared.com - online file sharing and storage - download wbr tejaram |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
06-29-2012, 08:18 | #7 (permalink) | |
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | 5800 After Write PM File SECURITY_TEST failed! - Solved Quote:
Thanks For The Share Bro : My Problem Solved After Write This PM Phone type: RM-356 (Nokia 5800 XpressMusic) SW version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia ApeCoreSw: V 60.0.003 Imei plain: 35800900033001-0 Product code: 0559408 Battery voltage: 4508 mV, current: 192 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358279030830010 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN | |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
Change Bin-file in Nokia..possible?? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-20-1999 16:56 |
5110 ver 5.24 scr file | friendlypirate | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-06-1999 05:04 |
how can we use *.scr files to unlock | shadow77 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-27-1999 03:13 |
