01-07-2011, 20:17 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | 5800 Erase Error..warning : erase sector address out of chip bound. when i untick the safe erase, phone gives this error, Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 13A00007097B005297482A782C65B3398E7A3CF4 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 CMT MuxOneNAND area [00000000-0FFFFFFF] Erase size: 256.00 MB CMT section, erased in 1.375 swarning : erase sector address out of chip bound. CMT MuxOneNAND area [00000000-0FFFFFFF] CMT MuxOneNAND area [0F720000-0FFFFFFF] Erase size: 264.87 MB CMT section, erased in 1.406 swarning : erase sector address out of chip bound. and this is the tick with safe erase log, Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 13A00007097B005297482A782C65B3398E7A3CF4 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 CMT MuxOneNAND area [00000000-0F71FFFF] Erase size: 247.12 MB CMT section, erased in 1.344 s |
01-08-2011, 15:00 | #2 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
any solution sir..? still waiting... | |
01-08-2011, 19:03 | #6 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | use one of this erase files(5800_Erase_256MB_kashi4gul or 256MB_RAPIDO_YAWE_erase_by_mm-gsm),after full flash with older version(example 21.0.025),write back rpl backup,write pm(without fields 120 and 308) with pm auth,repair simlocks,do sd repair with virgin pm field 1 and 309,again full flash with newer firmware. Hotfile.com: One click file hosting: 5800_Erase_256MB_kashi4gul.zip Hotfile.com: One click file hosting: 256MB_RAPIDO_YAWE_erase_by_mm-gsm.rar p.s.you will need tma adapter or other gadget to force phone to go in local mode after erase. |
01-09-2011, 15:48 | #8 (permalink) | |
thanx sir.. phone history: customer told me that after nsu update phone is dead and not power on again.. i really did what u say except erase file.. dead usb by mxkey,jaf, fbus flashing hwk,jaf, and mxkey..let me check ur solution.. | |
01-09-2011, 17:44 | #10 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | The phone can enter in local mode??, if yes the PLEASE make RPL back up, if not then dont try full erase, just try higher version to get local mode and can make back up, after that, flash the phone with medium E71 firmware then make Quick fix downgrade then flash back to 5800 firmware but try medium-high range.. Good luck.. |
01-10-2011, 10:59 | #11 (permalink) | |
01-10-2011, 11:20 | #12 (permalink) | |
sir these erase files are normal.? cause their extension is different from others.. 256MB_RAPIDO_YAWE_erase_by_mm-gsm.256 ==> *.256 5800_Erase_256MB_kashi4gul ==> not exist extension.. | |
01-10-2011, 11:47 | #13 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Hello friends , I have also a same problem in N76 , try to erase flash using untick safe flash option but at the end same error comes like loveless. when mobile come to me for repair it goes to local mode but now after flashing can't go into local mode . only nokia comes then white screen hang. I have already take certificates backup,but can't erase d flash also using erase file. please help me guys to solve d problem. |
01-10-2011, 11:54 | #14 (permalink) | |
Code: Phone Type: RM-346 (Nokia E71) SW Version: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia Imei plain: 12345610654321-? ApeCoreSw: 300.21.012 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
GID for nokia 5110 of telecel or TMN or Optimus? | hicom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-13-1999 15:29 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
