09-11-2011, 03:55 | #1 (permalink) |
Major Poster Join Date: Mar 2011 Location: Malaysia
Member: 1531473 Status: Offline Thanks Meter: 8 | 5800 with mxbox I read up the form and found out that its a software bug, i had to tick the "fast flash" So i tried, and it works, All MCU,PPM, CNT, APEv all flashed, but my phone is still dead, just vibrating. My phone now is unable to get into pooling mode. Advice needed! ThankYou in advance! |
09-11-2011, 07:29 | #2 (permalink) |
Member: 1531473 Status: Offline Thanks Meter: 8 | i tried erasing NPC. Phone is now able to on. But i do *#06#, imei is 12345610654321-? I restored RPL. Phone cannot turn on again.. Your help is much appriciated. |
09-11-2011, 08:16 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Edge of the world
Member: 492380 Status: Offline Thanks Meter: 184 | Quote:
What version of your HTI Box firmware? Try Install Latest version (v3.5 rev1.3) do shynchronize file. And update your firmware box to v00.17. Everything will be OK. | |
09-11-2011, 08:32 | #6 (permalink) |
Member: 1531473 Status: Offline Thanks Meter: 8 | as i said, i just bought mxbox yesterday, so i downloaded latest software, and upgraded latest firmware. everything is latest. i tried with phoenix, jaf all also end at pooling mode. |
09-11-2011, 09:51 | #7 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: pilapil marangle
Member: 1190283 Status: Offline Thanks Meter: 67 | Quote:
br | |
09-11-2011, 10:26 | #10 (permalink) |
Member: 1531473 Status: Offline Thanks Meter: 8 | anyone can use teamviewer and assist me? its quite hard to explain. --- I do have a backup rpl. Each time i restore this rpl, my phone cannot be turned on. But once i erase NPC, my phone is able to turn on but IMEI will be damaged. Does this mean my RPL is corrupted? i hope not. |
09-11-2011, 11:37 | #12 (permalink) |
Member: 1531473 Status: Offline Thanks Meter: 8 | okay this is latest update. i have successfully flashed my 5800, security, wd everything all correct. Now new problem, When i conenct my phone with fbus, my phone will power on, can enter every mode. I've used my phone in normal mode with fbus. Later on I disconnected everything and used battery, my phone cannot be turned on. I try charging it for 15minutes. no Hope. Retried using fbus, phone can power on.. 2 things i'm 100% sure. -Charger is NOT faulty -Phone charger socket is not faulty. |
09-11-2011, 12:12 | #13 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | dear mate check battery . charge it with external power supply and check battery pins is that all gud n tiet or open ? that not connect to battery terminal on board properly.... BEST OF LUCK |
09-11-2011, 12:13 | #14 (permalink) | |
flash again enofile search here. then fullflash again using usb conection. ........ | |
09-11-2011, 12:40 | #15 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | Quote:
pm to me your messenger id. | |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
