Old 02-24-2010, 10:18   #1 (permalink)
Member: 573283
Thanks Meter: 5
Help,how to fix the phone with SD damaged and SL=0000000?
The logs as follow:
Phone Type: RM-243 (Nokia 6120)
SW Version: V 07.10 15-07-09 RM-243 (c) Nokia
Imei plain: 356***03001834-3
Product Code: 0581707
ApeCoreSw: 07.10
ApeVariant: rofs_version_inforofx_version_info
ApeTest: rm243_ENO_A_2009wk15v0.100
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Bros, please help, how to do, any process step?? Thanks!
Old 02-24-2010, 10:22   #2 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
reapir simpock
repair sd and write pm 1 and 309 field with super sd
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 02-24-2010, 10:29   #3 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 813
Originally Posted by Smartmio View Post
The logs as follow:
ApeCoreSw: 07.10
Language Pack:
- not available.
SIMLOCK invalid!
see this guide my friend you can in minets it
(bb5>>sevice>>imei&securty>>imei rebold>>backup rpl all section>>
repair sd ) now go to pm section only super sd auth betan clik
br naveed butt
Old 02-24-2010, 10:56   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
i thinks this clear step
Just an information.
starting from mobileEx 3.3 Rev1.5, now repair SL and SD is done by single button "repair SD".
So if you want to repair SL, the whole procedure is as simple as:
1. backup RPL(just in case).
2. erase EEPROM.
3. Repair SD
4. Full Factory
5. SUPER SD Auth + Write PM1,309
if these steps still not fix the phone, please do BB5 Cert Validation + repair procedure as described on previous post above.
ps.
be sure that you are always using the latest release nokia module
(Option > Nokia Service Tool > Update)
original post
[MXKEY - TIPS] MXKEY in practice - What you should know about mobileEx -
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 02-24-2010, 11:26   #5 (permalink)
Member: 573283
Thanks Meter: 5
br naveed butt
Above Bro,Thanks........
how to flash the phone with same product code preshaust Cyclonebox 7 02-01-2011 13:44
How to repair the phone is SD keyde MX 3110c ramazan.keskin MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-10-2010 13:16
how to fix confirguration key with cyclone [Job done with the last update] bolaji olugbani Cyclonebox 3 01-05-2010 09:53
How to fix the phone with dead USB boot for Z500 sim1 QUALCOMM Models (3G) 3 08-29-2005 14:05
How To Fix The Cable To Fisio 355 ? I Need Help sunrise gsm Redbox 17 01-27-2005 10:41
Page generated in 0.20737 seconds with 9 queries
