02-03-2010, 10:07 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 582669 Status: Offline Sonork: 100.1592908 Thanks Meter: 69 | 6020 aft unlock restar in 2mins.. Phone Type: RM-30 (Nokia 6020) SW Version: V 05.22 23-05-07 RM-30 (c) Nokia. Imei plain: 35537*******-1 Imei OTP: 35537******* Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: W Language Pack: - not available. Imei net: 35537******** Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
02-03-2010, 11:48 | #8 (permalink) |
Member: 582669 Status: Offline Sonork: 100.1592908 Thanks Meter: 69 | Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-30.ini Saved INI not found, loading INI list... WARNING! Update your Pkey to increase life counter! Setting local mode... Reading product code... Product Code: 0515179 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-30\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.220 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22c CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22.image_tmn_pt3 ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Done! WARNING! Update your Pkey to increase life counter! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE WARNING! Update your Pkey to increase life counter! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE WARNING! Update your Pkey to increase life counter! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE WARNING! Update your Pkey to increase life counter! Switching to serial... Powering the phone... Reading... MCU SW version: V 05.22 23-05-07 RM-30 (c) Nokia. PCI version: UEM version: 400 UPP version: 8514 RFIC version: 0205 DSP version: P05w06.v40 LCD version: AMAZON PPM version: V 05.22 23-05-07 RM-30 (c) Nokia. C Production serial number: Product code: 0515179 Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 355375007784801 IMEI spare to net: 3A 55 73 05 70 87 84 00 IMEI SV to net: 33 55 73 05 70 87 84 10 F6 Master Code: 7575503767 Phone type: RM-30, Software version: 05.22, Language Pack: C User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-30.ini Saved INI not found, loading INI list... WARNING! Update your Pkey to increase life counter! Setting local mode... Reading product code... Product Code: 0515179 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-30\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.220 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22c CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22.image_tmn_pt3 ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Done! Backing up PM Field 208 as RPL... WARNING! Update your Pkey to increase life counter! Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\355375007784801_imei_back up_16332.rpl Done! Backup imei OK! WARNING! Update your Pkey to increase life counter! MCU: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.220 Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 882E0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x2E882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5538; Loader chk: be Loader is ready... WARNING! Update your Pkey to increase life counter! P-key nokia module version 01.02 MSID: 84FD5B4600C0BA7B74AC1F7431 MSID decoded: 28C7BAE900C32393AA000000 FAID: 85B2DA965F9D62B375CE6798 Operation took 0 minutes 7 seconds... Erasing... Found 3 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 0185FFFF... Erasing area: 01E60000 - 01FDFFFF... Operation took 1 minutes 15 seconds... Writing... Perm. Data Restore OK Operation took 5 minutes 27 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22.image_tmn_pt3 Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 882E0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x2E882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5538; Loader chk: be Loader is ready... WARNING! Update your Pkey to increase life counter! P-key nokia module version 01.02 MSID: 8446E1E702DC5B6037A6755133 MSID decoded: 1C15BAE300C32393AD0005BD FAID: 044837F44A81A493AAF01854 Operation took 0 minutes 7 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01A60000 - 01E5FFFF... Operation took 0 minutes 31 seconds... Writing... Writing converted flash to 128k page Perm. Data Restore OK Operation took 0 minutes 57 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Running: (c) Nokia File Server CNT Extract Skiped. Operation took 0 minutes 0 seconds... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22c Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 882E0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x2E882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5538; Loader chk: 5e Loader is ready... WARNING! Update your Pkey to increase life counter! P-key nokia module version 01.02 MSID: 84A560C21AA5EA198BA5A7D99C MSID decoded: 3E4EBAE900C32393AA000000 FAID: 0D9E90A0C30CD98DCA1B646B Operation took 0 minutes 7 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 01860000 - 01A5FFFF... Operation took 0 minutes 15 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 2 seconds... Restarting MCU... Flashing Done! Operation took 10 minutes 5 seconds... After flash processing... Waiting for phone to boot... WARNING! Update your Pkey to increase life counter! Reading... Phone type: RM-30, Software version: 05.22 IMEI: 355375007784801 Product Code: 0515179 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Failed! Aborting! Failed! Aborting! WARNING! Update your Pkey to increase life counter! Setting local mode... Error setting local mode!!! Done! WARNING! Update your Pkey to increase life counter! Powering the phone... Failed! Aborting! |
6233 sd seccessfully in 2min | JINDALGSM™ | Genie Universal | 2 | 02-23-2010 15:50 |
World first lastest s8300 unlokcked in 2min ::: GOOD WORK, THX ::: | chiragp | PolarBox 3 | 5 | 08-04-2009 15:50 |
J700 Orange Romania ,No network aft.unlock | dadustar | UST Pro II | 1 | 10-10-2008 02:42 |
BB5 RPL in 2min,Serious Auto Server,Unique Service+Free WebServer For Big Resellers | makona | Main Sales Section | 0 | 08-17-2008 16:32 |
5200 auto off in 2min. | Chandreshswami | Nokia Hardware & Hardware Repair | 4 | 07-29-2008 08:01 |
