03-12-2010, 10:30 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: SLOVAKIA
Member: 194282 Status: Offline Thanks Meter: 9 | 6120c unlock failed ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed SIMLOCK_DATA corrupted! |
03-12-2010, 10:32 | #2 (permalink) | |
Freak Poster Join Date: Aug 2008 Location: inside my brothers Age: 40
Member: 847198 Status: Offline Sonork: 100.1601641 Thanks Meter: 271 | Quote:
before unlock try to solve SUPERDONGLE_KEY invalid! just attach pm then unlock | |
03-12-2010, 10:40 | #3 (permalink) |
Freak Poster Join Date: Sep 2007 Location: FPS-21 The best nokia prommer!
Member: 590644 Status: Offline Thanks Meter: 146 | Hi Afo, 6120c is a SL2 phone. Now, you have a corrupted simlock e Super_Dongle_Key invalid. - Before unlocking, you have to repair simlock (By Simlock_RPL) and in second time "Repair SD". - After this two repairs you can press the unlock button. PS, if after the "repair sd", you Get security_test failed, you have to load into your phone the fields 1 and 309 by a good PM system (taken from the same type of phone) BR Freeck! |
03-12-2010, 11:05 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | SIMLOCK & Superdongle repair 1. backup NPC RPL. ( Service - IMEI& Security - IMEI Rebuilt - selct option as NPC - backup RPL ) 2. erase EEPROM only ( Flash - Advanced - Get address - tick eeprom - erase flash ) 3. Repair SUPERDONGLE 4. Full Factory ( Service - Actions - tick "Full Factory" - reset selected ) 5. SUPER SD Auth + Write PM1,309 br, |
03-12-2010, 11:37 | #6 (permalink) |
Member: 194282 Status: Offline Thanks Meter: 9 | thanks, I have a solved problem SUPERDONGLE_KEY invalid! but unlock this phone is not possible , always when I make unlock backup, phone is BLOCK 1: 1=LOCKED (MCC+MNC): 23210F, DATA=23210F when I pres unlock, phone is invalid simlock |
unlock failed sfr 112??? | gurbuz | FuriousGold | 2 | 03-30-2010 10:22 |
6120c unlock failed with new update of cyclone | gsmexpertgsmexp | Cyclonebox | 14 | 01-25-2010 21:12 |
6120c Unlock failed with Zulea 2.01 | wsw243 | Nokia Base Band 5 ( BB-5 ) | 1 | 06-22-2009 05:06 |
