Old 01-27-2010, 19:45   #1 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
6301 contact service
Phone Type: RM-322 (Nokia 6301)
SW Version: V 09.40 06-11-08 RM-322 (c) Nokia
Imei plain: 3589830-546-1
Product Code: 0556960
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
"RM-322" folder created.
SIMLOCK_DATA corrupted!
tell me solution step by step
if need to write pm file please upload here
thankss
Old 01-27-2010, 20:01   #2 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
after make simlock rpl
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 3589830----------5461
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
butt still contact service
Old 01-27-2010, 20:05   #3 (permalink)
.::Dr.Gsm::.'s Avatar
Member: 238374
Sonork: 100.1597005
Thanks Meter: 1,087
try to repair simlocks with repir simloks rpl in mx-key
Old 01-27-2010, 20:05   #4 (permalink)
Member: 238374
Sonork: 100.1597005
Thanks Meter: 1,087
post fulll information
Old 01-27-2010, 20:07   #5 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
check sl repair and repair your problem
Old 01-27-2010, 20:21   #6 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
cant repaired sl lock
Imei net: 358983-----5461
Counter: 0/3, 0/10
Backup already exist.
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11893, Date: 26-01-2010
Product: V 09.40 06-11-08 RM-322 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x3948 bytes) ...Communication problem, please make retry.
also changed cable
Old 01-27-2010, 20:23   #7 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 23500119FE0A6F5662F7B32F6E38D65E8867DAB2
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 917C7E9C635A433FAC3C0CFDABB536D164EF4ADA
Original Imei: 358983-----546
Original Product code: 0557400
Bluetooth ID: 001DFDBFECAA
WLAN ID: 001DFDCF2EEA
Imei plain: 3589830----546-1
Product Code: 0557400
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 01-27-2010, 20:25   #8 (permalink)
Member: 238374
Sonork: 100.1597005
Thanks Meter: 1,087
Wink
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
only press sx4 and write pm without 308 and 120
or contect me on
[email protected]
The Following User Says Thank You to .::Dr.Gsm::. For This Useful Post:
Old 01-27-2010, 20:55   #9 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
problem solved butt nothing me
aall credit is going to
adeelsaeed1
he is a goooooood person
The Following User Says Thank You to chand_gee For This Useful Post:
Old 02-16-2010, 12:54   #10 (permalink)
Member: 27706
Thanks Meter: 8
adeelsaeed1
please post or pm a good pm
6301 contact service HalooMa MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 10-11-2009 09:17
6301 contact service abdeslam728 Cyclonebox 6 07-03-2009 17:01
6301 contact service Zoosman Nokia Base Band 5 ( BB-5 ) 1 05-24-2009 12:47
6301 contact service happpy Nokia Base Band 5 ( BB-5 ) 0 03-17-2008 15:20
need nokia 6301 contacte service me gsm2share Nokia Base Band 5 ( BB-5 ) 1 01-25-2008 03:53
Page generated in 0.19734 seconds with 9 queries
