Old 02-08-2010, 16:02   #1 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
7210c SUPERDONGLE_KEY invalid!...finally done
Scan
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35318003rea1One
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35318003rea1One
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Repair SD
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 07.23 17-07-09 RM-436 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot  ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 28.578 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_35318003rea1One_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
Scan
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Counter: 0/3, 0/10
SD Auth
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized :)!
Write PM
Writing PM from Node ...
Section: 1
 - Key: 0, size 12 bytes written.
 - Key: 2, size 70 bytes written.
 - Key: 3, size 70 bytes written.
 - Key: 4, size 70 bytes written.
 - Key: 6, size 276 bytes written.
 - Key: 7, size 276 bytes written.
 - Key: 8, size 276 bytes written.
 - Key: 10, size 384 bytes written.
 - Key: 11, size 384 bytes written.
 - Key: 12, size 384 bytes written.
 - Key: 14, size 384 bytes written.
 - Key: 15, size 384 bytes written.
 - Key: 16, size 384 bytes written.
 - Key: 17, size 32 bytes written.
 - Key: 19, size 16 bytes written.
Section: 309
 - Key: 0, size 4 bytes written.
 - Key: 1, size 2 bytes written.
 - Key: 2, size 12 bytes written.
 - Key: 4, size 12 bytes written.
 - Key: 5, size 12 bytes written.
 - Key: 7, size 12 bytes written.
 - Key: 8, size 12 bytes written.
 - Key: 17, size 12 bytes written.
 - Key: 22, size 12 bytes written.
Completed in 1.328 s
Scan
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Procedure
1. Scan (if simlock invalid & superdongle invalid, please do simlock repair first then proceed to step 2)
2. go to Service option> IMEI & Security > IMEI Rebuild tab then click Repair SD
3. go to Flash option then click Scan (now Superdongle is Valid but security test falied)
4. go to PM tab and click SUPER SD
5. go to Service option> PM tab then click SUPER SD Auth
6. Write Modified PM
7. SCAN................Viola its Done. Superdongle key & Security Test are repaired
The Following 7 Users Say Thank You to rea1One For This Useful Post:
Old 02-11-2010, 05:13   #2 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
Thanks for replay but i am try this solution same condition
Old 02-11-2010, 05:35   #3 (permalink)
Member: 734616
Thanks Meter: 8
thanks you boss very good
Old 03-25-2010, 04:31   #4 (permalink)
Member: 169323
Thanks Meter: 28
thanks for this way, i tried but security test failed again.....??
** 7210c SimLock Invalid & SuperDongleKey Invalid Done ** kungpaoski MXKEY Nokia Flasher and Unlocker (by Alim Hape) 33 04-07-2011 07:49
7120c SUPERDONGLE_KEY invalid,SIMLOCK invalid!done. ...sewren... MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-25-2010 08:09
7210c SUPERDONGLE_KEY invalid! mahesh123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-22-2010 12:59
Help 7310c simlock superdongle_key invalid and invalid nardisk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-29-2010 19:38
Finally Done!! N95-RM159 simlock invalid SD repair lorenzo roberto Universalbox 1 12-25-2009 10:39
Page generated in 0.16953 seconds with 9 queries
