04-08-2010, 13:03 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Poland Age: 39
Member: 157756 Status: Offline Thanks Meter: 14 | 6303 CS - can i reapair this whit mx ?[SOLVED] SW Version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 35800503458177-4 Product Code: 0589155 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358005034581774 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Can I reapair SECURITY_TEST failed! whit mx key ? |
04-08-2010, 13:07 | #2 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Quote:
The Following User Says Thank You to akashub For This Useful Post: |
04-08-2010, 13:09 | #3 (permalink) |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | yes u can fix it with mxkey..but before anything else make sure to back up rpl...then sx4 auth then write pm..if no luck just search the post of mr hasnain in repairing contact service.. 5 steps |
The Following User Says Thank You to ELOY1024 For This Useful Post: |
04-08-2010, 16:21 | #4 (permalink) |
Member: 157756 Status: Offline Thanks Meter: 14 | In sl2 phone i know how to reapair this problem. @akashub, ok, but i have problem whit writing filed 308: Code: Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! Writing PM from Node ... Section: 1 - Key: 0, size 48 bytes written. - Key: 2, size 86 bytes written. - Key: 4, size 48 bytes written. - Key: 6, size 86 bytes written. - Key: 8, size 48 bytes written. - Key: 11, size 12 bytes written. - Key: 12, size 24 bytes written. - Key: 13, size 86 bytes written. - Key: 16, size 24 bytes written. - Key: 18, size 24 bytes written. - Key: 21, size 24 bytes written. - Key: 29, size 4 bytes written. Section: 2 - Key: 0, size 764 bytes written. Section: 3 - Key: 0, size 2 bytes written. Section: 4 - Key: 1, size 800 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 8 bytes written. - Key: 10, size 24 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 2 bytes written. - Key: 13, size 2 bytes written. - Key: 14, size 16 bytes written. - Key: 15, size 32 bytes written. - Key: 16, size 32 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 2 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 16 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 2 bytes written. - Key: 69, size 242 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 1 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 1 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 bytes written. - Key: 121, size 1 bytes written. - Key: 122, size 1 bytes written. - Key: 123, size 8 bytes written. - Key: 124, size 1 bytes written. - Key: 125, size 1 bytes written. - Key: 126, size 1 bytes written. - Key: 127, size 1 bytes written. - Key: 128, size 1 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 bytes written. - Key: 132, size 1 bytes written. - Key: 133, size 2 bytes written. - Key: 134, size 1 bytes written. - Key: 135, size 2 bytes written. - Key: 136, size 1 bytes written. - Key: 137, size 1 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 bytes written. - Key: 141, size 1 bytes written. - Key: 142, size 1 bytes written. - Key: 143, size 1 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 bytes written. - Key: 149, size 1 bytes written. - Key: 150, size 1 bytes written. - Key: 151, size 1 bytes written. - Key: 152, size 1 bytes written. - Key: 153, size 1 bytes written. - Key: 154, size 1 bytes written. - Key: 155, size 1 bytes written. - Key: 156, size 1 bytes written. - Key: 157, size 1 bytes written. - Key: 158, size 1 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 bytes written. - Key: 162, size 1 bytes written. - Key: 163, size 1 bytes written. - Key: 164, size 1 bytes written. - Key: 165, size 1 bytes written. - Key: 166, size 1 bytes written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. - Key: 169, size 1 bytes written. - Key: 170, size 1 bytes written. - Key: 171, size 1 bytes written. - Key: 172, size 1 bytes written. - Key: 173, size 1 bytes written. - Key: 174, size 1 bytes written. - Key: 175, size 1 bytes written. - Key: 176, size 1 bytes written. - Key: 177, size 4 bytes written. - Key: 178, size 2 bytes written. - Key: 179, size 1 bytes written. - Key: 180, size 1 bytes written. - Key: 181, size 1 bytes written. - Key: 182, size 1 bytes written. - Key: 183, size 1 bytes written. - Key: 184, size 1 bytes written. - Key: 185, size 1 bytes written. - Key: 186, size 1 bytes written. - Key: 187, size 1 bytes written. - Key: 188, size 1 bytes written. - Key: 189, size 1 bytes written. - Key: 190, size 4 bytes written. - Key: 191, size 2 bytes written. - Key: 192, size 1 bytes written. - Key: 193, size 4 bytes written. - Key: 194, size 1 bytes written. - Key: 195, size 1 bytes written. - Key: 196, size 10 bytes written. Section: 24 - Key: 0, size 1 bytes written. Section: 31 - Key: 4, size 18 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. - Key: 23, size 40 bytes written. - Key: 24, size 40 bytes written. - Key: 25, size 40 bytes written. - Key: 26, size 40 bytes written. Section: 44 - Key: 0, size 1 bytes written. Section: 49 - Key: 1, size 4 bytes written. - Key: 2, size 1 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 66 - Key: 0, size 509 bytes written. - Key: 1, size 240 bytes written. - Key: 2, size 240 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 240 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 240 bytes written. - Key: 12, size 1 bytes written. - Key: 17, size 4 bytes written. - Key: 19, size 4 bytes written. - Key: 21, size 4 bytes written. - Key: 23, size 4 bytes written. - Key: 25, size 4 bytes written. - Key: 27, size 4 bytes written. - Key: 29, size 4 bytes written. - Key: 31, size 4 bytes written. - Key: 33, size 4 bytes written. - Key: 65, size 8 bytes written. - Key: 82, size 3 bytes written. - Key: 83, size 3 bytes written. - Key: 84, size 3 bytes written. - Key: 86, size 3 bytes written. - Key: 87, size 3 bytes written. - Key: 88, size 3 bytes written. - Key: 90, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 102, size 4 bytes written. - Key: 116, size 1 bytes written. - Key: 121, size 8 bytes written. - Key: 123, size 7 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 2 bytes written. - Key: 1, size 20 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 120 - Key: 0, size 944 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 130 bytes written. - Key: 3, size 112 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 202 - Key: 0, size 1 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 250 - Key: 1, size 2176 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 742 bytes written. - Key: 4, size 40 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 308 Warning: failed to write 308 - 0 (1 bytes) Warning: failed to write 308 - 1 (8192 bytes) Warning: failed to write 308 - 3 (1 bytes) Warning: failed to write 308 - 4 (1 bytes) Warning: failed to write 308 - 5 (10 bytes) Warning: failed to write 308 - 6 (1 bytes) Warning: failed to write 308 - 7 (1 bytes) Warning: failed to write 308 - 8 (1 bytes) Warning: failed to write 308 - 9 (40 bytes) Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 17, size 12 bytes written. Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. - Key: 19, size 148 bytes written. - Key: 20, size 148 bytes written. - Key: 21, size 148 bytes written. - Key: 22, size 148 bytes written. - Key: 23, size 148 bytes written. - Key: 24, size 148 bytes written. - Key: 25, size 148 bytes written. - Key: 26, size 148 bytes written. - Key: 27, size 148 bytes written. - Key: 28, size 148 bytes written. - Key: 29, size 148 bytes written. - Key: 30, size 148 bytes written. - Key: 31, size 148 bytes written. - Key: 32, size 148 bytes written. - Key: 33, size 148 bytes written. - Key: 34, size 148 bytes written. - Key: 35, size 148 bytes written. - Key: 36, size 148 bytes written. - Key: 37, size 148 bytes written. - Key: 38, size 148 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 4408 bytes written. Section: 354 - Key: 0, size 3 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Section: 362 - Key: 0, size 1 bytes written. - Key: 1, size 120 bytes written. Section: 364 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. - Key: 23, size 40 bytes written. - Key: 24, size 40 bytes written. - Key: 25, size 40 bytes written. - Key: 26, size 40 bytes written. Section: 365 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Completed in 1 min 20.781 s After writing i have simlock data corrupted: Phone Type: RM-443 (Nokia 6303 classic) SW Version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 35800503458177-4 Product Code: 0589155 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
04-08-2010, 16:36 | #5 (permalink) | ||
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | you must "SKIP" when write PM 308 area before you have this Quote:
br, | ||
04-08-2010, 16:45 | #7 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | restore first until you get first condition. then do "SUPER SD AUTH" write PM [1] and [309] area. remeber : when MXKEY ask to write PM area 308 please ignore / skip that. never write that area from another phone br, |
04-08-2010, 16:52 | #8 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 313684 Status: Offline Thanks Meter: 35 | nokia 6288 blutoth prob do bt off set restart Phone Type: RM-78 SW version: V 06.43 30-03-07 RM-78 (c) Nokia ID Test name Startup Result 88 TAHVOINT Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 33 SIM_LOCK N passed 15 SLEEP_X_LOOP Y passed 56 SLEEPCLK_FREQ N passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 21 LPRF_IF N !no signal 44 LPRF_AUDIO_LINES N !no signal 2 CURRENT_CONS N passed 43 LCD N !no signal 42 RADIO Y passed 37 SEC_CAMERA_IF N passed 69 BACKLIGHT Y passed 93 SECURITY N passed 90 PWR_KEY N passed 71 BT_WAKEUP N !no signal 99 IRDA_LED_STRESS N passed 101 BTEMP N passed 107 BT_SLEEP_CLK N !no signal 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 85 CDSP_TX_IQ N passed 74 CDSP_TXC_DATA N passed 82 CDSP_PWR_DETECTOR_BIAS N passed 79 CDSP_RX_PLL_PHASE_LOCK N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
04-08-2010, 16:52 | #9 (permalink) |
Member: 157756 Status: Offline Thanks Meter: 14 | Phone Type: RM-443 (Nokia 6303 classic) SW Version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 35800xxxxxxxxxx Product Code: 0589155 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3580xxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Phone working fine whitout CS Thank you all for your help ! |
04-08-2010, 16:54 | #10 (permalink) | |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
and make new thread @haber thanks for your report br, | |
nokia 6303 cs problem 100% ok | MR.MAMUN | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-07-2010 15:41 |
can i repare this in mx key | ashokassag | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 04-07-2010 12:18 |
any one need 6303 cs solution 100% 100% 100% | ROYAL-GSM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 04-02-2010 12:18 |
any one need 6303 cs solution | ROYAL-GSM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 04-02-2010 06:05 |
Can this problem be solved by mx-key | shola5 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-24-2010 16:01 |
