Old 04-19-2010, 15:54   #1 (permalink)
Member: 772651
Thanks Meter: 1,694
6300 and 3110c security test failed
i have 6300 and 3110c which shows security test failed
Phone Type: RM-217 (Nokia 6300)
SW Version: V 06.60 21-05-08 RM-217 (c) Nokia.
Imei plain: **************
Product Code: *****
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: ***********
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
same for 3110c also
Need Help Please
This all hapend by writing PM
Old 04-19-2010, 16:03   #2 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 217
@ ajit bs
brother, why u seeking help????
do u search the mxkey section???
by the way do the following job. hope ur problem ill be solve
backup rpl
rest npc
go to pm click erase pm
writ rpl then click recover cert
repair sd
go to pm >click sd auth writ pm
reply here, if u still face this problem
The Following 4 Users Say Thank You to sanjoychy For This Useful Post:
Old 04-19-2010, 16:15   #3 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
http://forum.gsmhosting.com/vbb/f550...l-here-945700/
Old 04-19-2010, 17:59   #4 (permalink)
Member: 772651
Thanks Meter: 1,694
Originally Posted by sanjoychy View Post
@ ajit bs
backup rpl
rest npc
repair sd
@ ajit bs
backup rpl
rest npc
repair sd
actually brother when both sets came to were ok, both had a network problem . when i scan both sets with mx-key it shown
SIMLOCK_TEST passed
SECURITY_TEST passed
then i wrote PM and again made a scan it shown
SIMLOCK_TEST passed
then itried to switch on the both sets 6300 & 3110c .. both got in contact service where as imei number of both sets are ok
now when i m trying to write with 1 and 309 field it shows warrning failed to write 1 and 309 field
please help step by step so that i can solve my problem
Old 04-19-2010, 18:17   #5 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
pls do it step by step
1_mxkey>serves>imei&securty>imei rebuild>repair sd
2_go to pm >click super sd auth and writ pm
3_full factory
The Following User Says Thank You to alasmmar For This Useful Post:
Old 04-19-2010, 18:36   #6 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
check rpl backup in note pad or see rakesh15 post urproblem solve 100%
Old 04-19-2010, 19:05   #7 (permalink)
Member: 772651
Thanks Meter: 1,694
3_full factory
i already gone through these steps please help further
Old 04-19-2010, 19:13   #8 (permalink)
tanveeranjum's Avatar
Member: 386511
Thanks Meter: 305
3_full factory
try...............................
The Following 2 Users Say Thank You to tanveeranjum For This Useful Post:
Old 04-19-2010, 19:46   #9 (permalink)
Member: 772651
Thanks Meter: 1,694
3_full factory
how to do 3rd step full factory
Old 04-19-2010, 20:15   #10 (permalink)
Thanks Meter: 4,071
Arrow
do this way:
1: http://forum.gsmhosting.com/vbb/f299...1000-a-965626/
2: http://forum.gsmhosting.com/vbb/f299...e-here-962316/
3: http://forum.gsmhosting.com/vbb/f299...-files-915468/
Old 04-20-2010, 06:31   #11 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 217
@ ajit bs
Brother sorry for late response.
hope still u have faced this problem
just connect ur phone with mx key.
Go Service > Imei & Security > Imei Rebuild
then click Write Rpl option and write these rpl.
and post the result
File Type: rpl 3110c_without_NPC_DATA__made_by_MxKey.rpl (1.8 KB, 87 views)
File Type: rpl 6300_without_NPC_DATA__made_by_MxKey.rpl (1.8 KB, 218 views)
Old 04-20-2010, 13:01   #12 (permalink)
Member: 772651
Thanks Meter: 1,694
3_full factory
i tried .... i did ist repair SD and then in PM tab i did SUPER SD Auth. with PM 1 and 309 ..i got this error
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010)
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
Using cached productData[26C0010399357C56FEFA869E9631022A40D10FAA] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (86 bytes)
Warning: failed to write 1 - 18 (86 bytes)
Warning: failed to write 1 - 20 (86 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 29 (6 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 0.500 s
need immidite help
Old 04-20-2010, 13:08   #13 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
Section: 1
Section: 309
need immidite help
put logs here after use scan button in mx key. i will help u
The Following User Says Thank You to unicomtogo For This Useful Post:
Old 04-20-2010, 13:12   #14 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro, u need erase pmm
backup rpl
rest npc
repair sd (you will get rpl to repair sim & sd)
go to pm >click sd auth and writ pm
fullfactory
Old 08-13-2010, 10:56   #15 (permalink)
Member: 687840
Thanks Meter: 12
Talking thanxxxxxxx a lot..........
3_full factory
hey buddy u have done reaally good job....its ok now......thnx lot once agian.
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.27432 seconds with 10 queries
