12-01-2011, 00:24 | #1 (permalink) |
Insane Poster Join Date: Feb 2009 Location: Phillipines
Member: 975567 Status: Offline Thanks Meter: 7 | 6680 after unlocking on HTI it becomes Security Test failed :( Log: Phone type: RM-36 (Nokia 6680) SW version: V 04wk47v35.2 25-04-05 RM-36 (c) Nokia. Imei plain: 35566400234670-2 Product code: 0524207 Battery voltage: 4929 mV, current: 83 mA ApeCoreSw: V 3.04.12 ApeVariant: V 3.04.12-Philippines 26-04-05 RM-36 (c)NOKIA Language Pack: English,German,Italian SLPA ver[1]: PA_SL (15 digit NCK) Security code: 12345 SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355664002346702 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Action taken : click super sd auth write Pm 1-309 = same result Click Recover certificate = error APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 54CFC1535D11CAF0F52113541BF89D8C0E6BAE8D ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] EM0 ID: 00000232 EM1 ID: 00000341 PUBLIC ID: 0F60000BEFA64F570842E0A99CFD5ADD8655F278 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 eBB5ProtocolType: OLD Storage0: 00EC 22FA - 0000 0011 [Samsung K8S6415ETA,64 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 Begin Certificate Request ... [InternalErrorFault] CERT [0524207] data not available for this phone (case id=0xCE01) Do we have 6680 modified Pm without NPC? Any solution team about this? |
12-01-2011, 00:32 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
hi.. use "pmm auth" then "load pm rffb server" and press "write" button.. post the results again.. | |
The Following User Says Thank You to LoveLess For This Useful Post: |
12-01-2011, 00:34 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
just follow on screen message carefully. BR | |
The Following User Says Thank You to gbluez For This Useful Post: |
12-01-2011, 01:08 | #5 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | oki just an advice... u can try this as final solution... backup the RPL.. all data... then erase the phone ( untick safe erase ) then flash the phone.. after succesfully flash imei will 1234... and check the security area again if still it is FAIL ur flash ic is damaged.. but if ur flash is PASS there is no pb with ur chip..after that try to rebuild cert and sd repair and pmm auth then modified pm or pm from server.. w.b.r |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
