11-22-2011, 12:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh
Member: 1201843 Status: Offline Thanks Meter: 487 | 6700s phone statup faild (ANSWERED) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.12920(08-10-2011) Processing MCU file: rm576_071.004_prd.core.fpsx [BB5,XSR 1.6] size: 88.43 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 250195F CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 17500112CB85034462E7987E9E998EBF537B1BF8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 250195F FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35376604995769_CE RT.rpl). CMT PAPUBKEYS HASH: B1302F79239A2431E816565B36374B1F676A23AC Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 177.06 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0B53FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: B1302F79239A2431E816565B36374B1F676A23AC (RAP Certificate 171 v.1) sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 15.781 s Processing PPM file: rm576_071.004_11.01_MEA_C_prd.rofs2.fpsx [BB5,XSR 1.6] size: 37.04 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 47.25 MB CMT MuxOneNAND area [07800000-0A73FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 6.765 s Processing PPM file: rm576_071.004_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.01 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 14 MB CMT MuxOneNAND area [0A740000-0B53FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.125 s Processing CNT file: RM576_ENO_11w02v0.049_APE.fpsx [BB5,XSR 1.6] size: 2.28 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 4 MB CMT MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.547 s Processing CNT file: rm576_071.004_URed006.000_prd.uda.fpsx [BB5,XSR 1.6] size: 3.55 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 65 MB CMT MuxOneNAND area [0B540000-0F63FFFF] Flash programming ... Programming completed in 1.110 s Total time for flashing process(boot+erase+write) was 58.500 s Waiting for device boot up ... Device found: nmwcdc\Nokia 6700 slide USB Phonet, PORT_ID: 10944B46 Verifying communication to device OK. Phone Type: RM-576 (Nokia 6700s) SW Version: V ICPR82_11w16.3 19-05-11 RM-576 (c) Nokia Imei plain: 35376604995769-8 Product Code: 0589371 Battery voltage: 4049 mV, current: 180 mA ApeCoreSw: 071.004 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353766049957698 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN need help thanks advance......... |
The Following User Says Thank You to rakib_sheak For This Useful Post: |
Nokia 3110c phone restricted | Rockybul25 | HWK | 18 | 06-26-2014 11:14 |
XP Cinta M-Star Chip Phone Lock | alamgarh | Dragon Box | 6 | 02-23-2012 10:51 |
