Old 06-21-2010, 11:04   #1 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
No RAP Flash Chip Detected......... Solution.
I have nokia 6300 which this error when flash this mobile.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2F000217CA268C56945F1467EFFB9E226348ADF1
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Original Imei: 00000000000000
Original Product code:
I need Solution any one help me.
Thanks to all GSM members.
Flash Tab Logs -
Processing file: rm217__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.406 s
CMT NOR area [000006C0-0001FFFF] erased in 0.156 s
CMT NOR area [00020000-0007FFFF] erased in 1.141 s
CMT NOR area [00080000-000DFFFF] erased in 0.484 s
CMT NOR area [00100000-001FFFFF] erased in 0.969 s
CMT NOR area [00200000-0031FFFF] erased in 3.188 s
CMT NOR area [00320000-0105FFFF] erased in 36.281 s
CMT NOR area [01060000-01067FFF] erased in 0.437 s
CMT NOR area [01068000-0107FFFF] erased in 0.406 s
Flash programming ...
CMT PAPUBKEYS: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 (RAP Certificate 52 v1) written.
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00704400, Result: 0010
Flashing terminated with error(s) in 4 min 14.782 s
RX Buffer: C7012D0103CD000010000000F172
The Following User Says Thank You to ravi mobile For This Useful Post:
Old 06-21-2010, 11:18   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
whats the phone story? blue light only at side.
Old 06-21-2010, 11:33   #3 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
Blue light blink when connect dongle not blink when insert battery
Old 06-21-2010, 13:37   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
its HW fault .
Old 06-22-2010, 13:51   #5 (permalink)
Member: 670138
the dongle said that the problem is in bsi pin,that means that the problem is between the cable or the bsi resistance it must be at the range of 7 kohm,second if that doesnt work you have to rehot the combo memory its the flash memory under the rapgsm the cpu,make 360 degree to 380 carefuly under the mother board and after clean it,and this two solutions works for me...
good luck...
Old 06-23-2010, 12:35   #6 (permalink)
vistasamir's Avatar
Member: 619931
Sonork: 100.1593005
Thanks Meter: 44
Its hardware problem...........
Old 08-01-2010, 08:48   #7 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
how to slove for my problem?
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 18B0010541F26C563571C122B3AC4767C469B5D4
ASIC MODE ID: 00
ID 32: 000200400000
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
Original Imei: 3586470xxxxxxxxx
Original Product code: 0537684
Bluetooth ID: 001D983A0C03
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.21 05-11-08 RM-217 (c) Nokia.
Imei plain: 3586470xxxxxxxx
Product Code: 0537632
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358647016933158
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
just restart if during on off pressed.
thanks for advance
The Following User Says Thank You to sumatera For This Useful Post:
Old 08-01-2010, 10:42   #8 (permalink)
Raznet's Avatar
Member: 564325
Thanks Meter: 104
it is most probably a hardware problem related to taivo ic either rehot it or reball it good luck
The Following 3 Users Say Thank You to Raznet For This Useful Post:
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.16144 seconds with 9 queries
