Old 01-14-2011, 11:48   #1 (permalink)
ali_7867's Avatar
Member: 910577
Thanks Meter: 242
Need help for mxkey team plsss
Need help for mxkey team plsss hi friends
can anyone tell me how to get the hsahs file from mxkey
pls bez i dont have super pc and i want to get the hsahs file
if anyone know pls pls pls let meknows thanks
mxkey is the best
ali_7867
Old 01-14-2011, 12:43   #2 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
1. Identify phones with "Scan Phone" (as usuall) to see if it is SL3 phone.
2. Go to "IMEI & Security" tab and select"Online Logger" it is sl3 100 credit logger.if you have.
3. Click "Login", and if your card is activated SL3 Unlock panel will be visible.
4. Click "Read Phones IDs" to prepare the data which is needed for bruteforce task
(this will also identify is phone is supported or not),
new file {IMEI}.sha will be created at folder "{MOBILEEX}\data\SL3\"
5. Click "Start Bruteforcer" and select {IMEI}.sha file.
Random Salt is checked by default which mean the task will using random data
to make bruteforce instead of using normal sequence.
6. After some time and the bruteforcer task completed, it will create file {IMEI}.cod
to the same folder as {IMEI}.sha file
7. Then go back to main exe, and do "Calculate Codes" to get the unlock codes,
unlock code will be saved as {IMEI}_SP_CODES.txt.
Tick "Send to the phone" to directly send the codes to the phone.
8. Task is done and the phone was unlocked, enjoy !
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.17373 seconds with 9 queries
