10-30-2010, 09:13 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 44
Member: 66510 Status: Offline Thanks Meter: 27 | 7210c SIMLOCK_DATA corrupted!error 0x14 (answered) Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2A80010779447D566F51FDEDEC9972C1B7AC2A82 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0566807)... OK Updating PSN (DTC424093)... OK Updating HWID (1000)... OK Updating SIMLOCK...error 0x14 Updating SUPERDONGLE_KEY ...OK Updating CMLA_KEY...OK Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35196203729883-9 Product Code: 0566807 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid Problam same http://forum.gsmhosting.com/vbb/f550...olved-1119101/ SIMLOCK_DATA corrupted! |
The Following User Says Thank You to sonu_pco For This Useful Post: |
10-30-2010, 09:25 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | so it's not solved yet? where have you been? to avoid thread closing by miss understanding, next time please use english. - backup rpl - just in case erase eeprom: get addr > untick safe erase, select eeprom only. press erase. - repeat simlock repair procedure, proceed with SD repair after. - check camrera, do repair dcc if needed. all described on sticky. start to read them. BR |
10-30-2010, 09:28 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | so it's not solved yet? where have you been? to avoid thread closing by miss understanding, next time please use english. - backup rpl - just in case erase eeprom: get addr > untick safe erase, select eeprom only. press erase. - repeat simlock repair procedure, proceed with SD repair after. - check camrera, do repair dcc if needed. all described on sticky. start to read them. BR brother not try this but u try this your mobile imei 1234560165432? and rpl erase |
10-30-2010, 10:02 | #6 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | @ iftikhar_246 i think u are forget to read some in mr.gbluez's post they ..said clearly .... backup rpl_ just in case .. if your set get imei 12345654321??? then just restore rpl backup(it is just in case.) and mr-gbluez give acruarate answer that's he is modrater .... |
10-30-2010, 10:08 | #7 (permalink) | |
Member: 66510 Status: Offline Thanks Meter: 27 | Quote:
10-30-2010, 10:15 | #8 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | 1) scan or bus check 2)go to sevice ( imei and seurity) 3) mark on pa-sl2 and make sim lock rpl 4)update splock |
10-30-2010, 10:17 | #9 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | nothing more i can say, read carefully: http://forum.gsmhosting.com/vbb/f550...ftware-747426/ http://forum.gsmhosting.com/vbb/f550...y-here-726058/ |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
