04-03-2010, 08:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: karoondi khairpur pakistan
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | check it if you have boot error problem You can downgrade your JAF firmware easily_______ it is 100% tested by me Now i use jaf 62,63,64 version_ and now my jaf box good work with mxkey___ at first download this potato jaf box firmware v.2.0 download herehttp://rapidshare.com/users/P5JHS5 here is many option for jaf box in the potato jaf box firmware v.2.0 1. at first by option one you connect your jaf box with potato jaf box firmware v.2.0 2. write last option in your jaf box from potato jaf box firmware v.2.0. this option is ______ """write jaf box with FW 01.B2 original- not recommended,buggy!!!""" 3. when write finished than you install jaf setup 61 or 62 or 63 or 64 4. now connect your jaf box with setup 61 or 62 or 63 or 64 ( with pkey or ogm this is not problem) 5. when you open jaf software you must need update your jaf box.... now just click update firmware... 6. update successful 7. now re open jaf software 8. at last solved your all problem and jaf box good work with jaf software and mx-key software it is 100% tested post your result |
The Following User Says Thank You to AMEERGUL For This Useful Post: |
checking your BL verstion and downgrading the baseband if you have 5.08- the easy way | sniry | iPhone 2 / iPhone 3G / iPhone 3GS | 12 | 04-17-2009 00:02 |
Looking for these ICs let me know if you have it | GFI | Wanted Products | 2 | 07-13-2007 06:09 |
If you have polarbox and w375 for test... try it | Uvedovle | Motorola ODM | 0 | 03-09-2007 11:18 |
If you have sumo smash or jungle rumble for nokia 3300/s40 sen it to me. | Ugaskunkka | Java, iOS, Android, Symbian development | 0 | 09-12-2005 18:44 |
V975 If you have 0x1dE error | Nokall | Smart-Clip | 1 | 06-10-2005 19:49 |
